Ground wire to fender.
Pic has been found! It was on the laptop a friend was cleaning up from a virus attack. I had to go to his house to get it but while I was there I bought a part from a forum member.
Here is what I plan to do. 1). Chase threads with a tap and die set (dad will help me) to clean out new paint. 2). Mark area covered by that round connector. Use Dremel tool to clear off that area of paint and get it down to bare metal. 3). Use dielectric grease to prevent rust on fender area under connector. *If anyone has a bolt that will fit that hole and will spare it, I'll pay you for it. Thoughts? |
Re: Ground wire to fender.
glad you found that picture
Moderator
![]() Join Date: Jun 2017
That bolt is the same as the fender inner to fender bolts, except for the star washer....
BTW...you do know that lead is not factory,,,its a crimp end someone made up at some time to replace the original ground strap..ground straps are usually open weave copper flat style leads with soldered ends.... See: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=188 One note...and I see this so often....the star washer goes between the fender and the lead, with the flat washer bearing directly on the flat terminal of the lead. The pic shows the washer was outside of the connection... The purpose of the star washer is two fold...it acts a a shake proof washer, but more importantly, the sharp edges of the washer bind into both the fender and the cable end, ensuring a good connection..just clean the area around the bolt hole to match the size of the cable end, clean the inner face of the cable end with sand paper and place a little dielectric grease on the washer, tighten it down and you will be good to go. ![]() ![]() ![]() |
#4 | |
![]() I thought the same thing about that washer....that it was on the wrong side of the connector. ![]() |
