Old 10-02-2017, 06:31 PM   #1
buds56
buds56's Avatar
61 C-10 windshield install difficulties
I went to install the original windshield back in my 61 and I spent several hours trying to get the rubber gasket on the windshield with no success.
I don't want to break the glass but I can not get the rubber spread enough to go over the glass.
I have put these type in on my previous 56 truck and 55 car.
I bought a classic industries gasket which reads precision on it.
Has anyone had similar problems?
Do I need a better quality gasket i.e. Steele? $100
Is there a tip or trick someone could share with me?
buds56 is offline   Reply With Quote
Old 10-02-2017, 06:41 PM   #2
jayoldschool
Moderator
Re: 61 C-10 windshield install difficulties
What's the Precision part number you're using? Precision is very good, btw. I'm wondering if you're trying to use a 64-66 on it instead of a knee knocker.
jayoldschool is offline   Reply With Quote
Old 10-02-2017, 07:17 PM   #3
buds56
buds56's Avatar
I don't have the # handy but it looks long enough for the wraparound, my problem is spreading the groove or slot enough to go over the edge of the glass, its very stiff.
I set it out in the sun, warmed with a heat gun, cut down two putty spreaders and put them on each side of the glass with them in the groove and tried to slide the rubber on to the glass with no success, there is no way the corners will survive the amount of pressure I put on the flat sides.
Old 10-02-2017, 08:12 PM   #4
Brad54
Brad54's Avatar
i had that problem with one for a '61 Corsair station wagon. No WAY it was going on.
Called them, had the correct part number, correct markings on the rubber... it was the right one.
Sent it back, they sent me a new one--same part number, same markings on the rubber, same look, same corners, and it practically jumped out of the package and wrapped itself around the edge of the windshield. They couldn't explain it, and neither can I.
I wonder if the cooling rate of the rubber might sometimes affect the fit or shrinkage. I dunno. But two "identical" gaskets from the same manufacturer, and one wasn't going on, the other fit perfect.
You might be dealing with the same thing here.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-02-2017, 09:10 PM   #5
Heater63
Heater63's Avatar
I had no problems with the Precision gasket in my 63. Local glass shop with an old school brother installed my windshield in 30 minutes.
I suspect something is not correct with your gasket.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 10-03-2017, 08:53 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Here are a couple of how to videos on the subject with some tips:
https://www.youtube.com/watch?v=zA8sX1KR6J0
https://www.youtube.com/watch?v=LsSB4Kad4qA
Old 10-03-2017, 09:41 AM   #7
oldusafmsgt
oldusafmsgt's Avatar
Buy a seal from Steele Rubber. The cheap imported crap is worthless.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 03-18-2018, 07:22 PM   #8
buds56
buds56's Avatar
I bought one from Steele, got it on the glass but still couldn't get it in the truck.
Had a glass guy come out and install it, went right in.
Old 03-18-2018, 09:28 PM   #9
Cooper197
Cooper197's Avatar
Mind me asking what it cost to have somebody install it? I'm about ready to have mine put in and just want to make sure I'm in the ballpark price wise.
Cooper197 is offline   Reply With Quote
Old 03-19-2018, 12:02 PM   #10
buds56
buds56's Avatar
$250
Where my garage is fairly remote, hard to find anyone to come that far out.
Old 03-21-2018, 11:01 AM   #11
w00dst0ck
w00dst0ck's Avatar
No idea what brand mine is, but it went on really easily. It leaks like fu*king crazy. It's so loose I can lift it away from the glass with my fingers. I can also manipulate it a little up/down. Glass guy provided the glass and seal. I'm wanting to get it redone, waste of $250.
w00dst0ck is offline   Reply With Quote
Old 03-23-2018, 02:34 AM   #12
Cooper197
Cooper197's Avatar
Originally Posted by buds56 View Post
$250
Thanks! I found a place that came highly recommend today that's going to do mine next week for $267 parts and labor at my place. Lifetime warranty on seal and labor. Seems like a decent deal!
Old 03-23-2018, 07:39 AM   #13
Dhaak64
Yep, I’m in the same situation. I bought windshield rubber from LMC. It leaks like crazy too. Won’t do that again!
I will be going with precision on the next go around.
Dhaak64 is offline   Reply With Quote
Old 03-23-2018, 11:34 PM   #14
Captainfab
60-66 Nut
So a new '60-'63 windshield with new rubber installed for $267?
Old 03-24-2018, 11:15 PM   #15
Cooper197
Cooper197's Avatar
Mine's a '66 but otherwise yes. Will be curious to see how it goes...
Old 03-25-2018, 01:50 AM   #16
Captainfab
60-66 Nut
The '64-'66 windshields are much cheaper than the '60-'63 windshields. That's why I was questioning your price since this thread is about the '60-'63 windshields.
Old 03-25-2018, 02:45 PM   #17
61K10
61K10's Avatar
a couple of yrs ago my 61 was around $170 plus install. Total was $263.00. windshields are suppose to be sealed with a sealer, not just the rubber.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
