Sway Bar mount
Just mount my sway bar from CPP.
Had to drill 2 new holes for fittment. I´m verry pleased with my work, but I need to know if the end link on the lower control arms is in right order? And how hard I must tighten. |
![]() Join Date: Oct 2014
Re: Sway Bar mount
Your end link assembly is wrong. Here is the order of assembly.
From the bottom to the top. Bolt goes up from under the lower control arm, flat washer, poly bushing with lip facing control arm, then on top of control arm poly bushing with lip facing down, flat washer, metal spacer, flat washer, poly bushing with lip facing up through the bottom of sway bar end, poly bushing with lip facing down on top of sway bar end, flat washer and nyloc nut. Hope this helps. Sorry I don't have a pic to show you. Phil
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
Re: Sway Bar mount
Agree it doesn't look right. The sway bar should be near the tip of the end link. On my '67, there is no end link, the bar is clamped tight to the arm with a bushing and clamp, just like you have there on the frame rail.
Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#4 | |
Re: Sway Bar mount
Re: Sway Bar mount
As you can see, the end link is "tilted"? The mounting holes on the bar didn't exactly measure the holes on the arm. Is that normal with aftermarket proceeds?
Re: Sway Bar mount
Re: Sway Bar mount
Here is how they should be assembled (if this doesn't make sense, you need someone to come help you):
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Sway Bar mount
Re: Sway Bar mount
I'll assume you have cut springs to lower the front end. During my install, I once again was reminded how beneficial drop spindles are. Check for any touches between your sway bar and steering components after a short drive.
Re: Sway Bar mount
Yes. That's why I mounted it like that in the first place. But at the same time it didn't feel right.
Re: Sway Bar mount
I didn't cut the spring
Re: Sway Bar mount
The former owner must have. 1 or 2 inches. I can't tell.
#13 |
Re: Sway Bar mount
Do you think I could use a shorter bolt, and skip one of the poly bushing?
#14 | |
Re: Sway Bar mount
I'm going to stick my neck out and say that you used the existing holes in the control arms from the original style sway bar mounts. They do not mount the end links straight up and down, you will need to drill different holes as you will see or they will be in a bind the entire time. But, I would just fix the bushing order and see how it is. Good luck, when common sense falls into place and it all gets done post some pictures.
#15 |
Junior Member
![]() Join Date: Jul 2014
Re: Sway Bar mount
All good advice. I'm using the same bar on a stock height. The end links aren't designed to be used with the link mounted directly to the arm. The hole you are using is one of two for mounting a strap bracket that used a bar with a straight end. The CPP bar has a hole on the end to use the end links instead. When using links the way you are, it's best to use an L-bracket which mounts to the front of the lower arm. There may already be a hole there, as there was on my truck, but the CPP bar was shorter, so I had to drill new holes about three inches closer together. The CPP bar was actually sized to work with their tubular lower arm which already has the end link bracket to match the bar. Hope this helps.
#16 | |
Re: Sway Bar mount
#17 | |
Re: Sway Bar mount
One question:How hard do I tighten the end link? Because of the poly busching it seems to be no stop? |
#18 |
![]() Join Date: Apr 2013
Re: Sway Bar mount
gotta use a L- bracket for these end links...
CPP sells these brackets
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#19 |
Re: Sway Bar mount
Show me how
#20 |
Re: Sway Bar mount
Looking better! Not far away now. I'm not familiar with the L-Bracket from CPP but it probably fixes your orientation due to the end link being mounted in a hole meant for a "strap" type "hold-down" like so...
#21 |
Re: Sway Bar mount
[QUOTE=weq92f;8053685]Looking better! Not far away now. I'm not familiar with the L-Bracket from CPP but it probably fixes your orientation due to the end link being mounted in a hole meant for a "strap" type "hold-down" like so
So you don't think this will work? |
#22 |
Re: Sway Bar mount
Yeah, it looks like it might be fine, but with those end links, you want to install them correctly. PowerdbyChevy79 seems to be on to something about using the bracket to correctly position the end link in the arm.
The holes you're using weren't meant for use with the end link piece, but rather were meant for use with the hold down strap type mount. I suspect the bracket will prevent you from having to drill through the arm for proper placement of your end link. Give CPP tech line a call about the bracket or hit their site for it. As for the tightening, you may find a torque spec on CPP site or elsewhere. If not, just tighten real snug but don't crush the rubber bushings at either end of the end link. Hth, -klb
#23 | |
Re: Sway Bar mount
http://www.classicperform.com/Store/...ck/6372SBK.htm
#24 |
Re: Sway Bar mount
That's the one I bought
#25 | |
Re: Sway Bar mount
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
