Old 10-03-2017, 07:40 PM   #1
Chevylvr7
Question Electrical
71 350 longhorn,
new alternator, new battery, new starter, new ignition switch, new HEI dist.
Won't fire, tried everything.....HELP!!!
Had a battery explode, since then it's been a nightmare.!
Chevylvr7 is offline   Reply With Quote
Old 10-03-2017, 07:52 PM   #2
Coley
Coley's Avatar
Re: Electrical
...will it turn over?
Have you checked 7 times to make sure that your (new) HEI distributor is timed correctly to fire for #1 at TDC.
A lot of installs get this wrong or out by 180°.
The best way is to check it on the damper, remove the valve cover to view the valve/spring position and then check it in the cylinder with the plug removed.
If that is ok....is your HEI actually firing off a spark?
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-03-2017, 08:08 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Re: Electrical
Battery explosion...WOW!
Did you figure out what caused it?
Ok...back to basics...
1/ Ign on, do you have 12 V on HEI + connection? Supply wire from Ign switch must be 12 G or larger...make sure you havent connected Ign to Tach terminal on HEI connector...
2/ New HEI distributor...does it have the module in it and is it wired correctly?
3/ Missing rotor button?
4/ Distributor timed correctly? Bring cyl #1 to TDC on compression, remove the cap and make sure rotor is pointing to #1 cyl...firing order clockwise, 18436572......see pic...
5/ Does the starter spin the engine over?
Usual suspects...
fuel supply ok?
does the rotor spin when engine cranks over?
AussieinNC is offline   Reply With Quote
Old 10-03-2017, 08:10 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Re: Electrical
All Good
Coley
I always check em 8 times...not 7....once for each firing cycle...haha
But I do know what you mean...not first time its bitten me...
Old 10-03-2017, 10:10 PM   #5
franken
Re: Electrical
You need to get a voltmeter and describe the problem with more than won't fire.
franken is online now   Reply With Quote
Old 10-03-2017, 11:11 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Electrical
Battery explosions are usually due to loose terminals sparking during cranking. OR you could be like a guy I used to work for that would hook a 12V battery up to jump start a tractor with a 6V system. Fortunately the big chunks missed me, and I got the acid rinsed off before I went blind. Lots of crazy running loose in the world.
Please provide us with some pictures. They may help in the diagnosis.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-04-2017, 04:02 PM   #7
demian5
demian5's Avatar
Re: Electrical
Drop a Q and run.
Did the truck have HEI before? If no, you need to run a new wire from the fuse block to the HEI.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-04-2017, 04:37 PM   #8
Coley
Coley's Avatar
Re: Electrical
....good point.
How many volts do you have at the HEI right now with the main power wire?
If you are using the original, tiny little yellow power (+) wire...you might have 8 volts or less arriving at your HEI unit and this isn't going to cut it.
Check this voltage....and post up the number.
All Good
Coley
2000 Dodge Ram 1500
Old 10-04-2017, 05:12 PM   #9
In The Ten Ring
Re: Electrical
Anytime working with a battery, SAFETY GLASSES/FACE SHIELD.
In The Ten Ring is offline   Reply With Quote
