Old 10-04-2017, 06:24 PM   #1
kevz51
Speedeometer
Speedometer 92 g20 van to fit stock cluster. Does anyone have the email of the guy on here that makes them? Thanks guys
kevz51 is offline   Reply With Quote
Old 10-05-2017, 10:57 PM   #2
68c10airstream
68c10airstream's Avatar
Re: Speedeometer
Welcome aboard, ls1nova71 did the thread on using a stock 96-97 s-10 speedo and making it work in the stock cluster. I haven't seen a g20 speedo used. Get with him if this is your direction. Eric (ls1nova71) does a vinyl overlay, stencil for new mph numbers, etc. He will direct you to the board member that makes a metal box that houses the s-10 speedo head. I did this mod and love it, works perfectly! Eric is a fantastic help, you are in good hands.
Good luck, and no matter which speedo you use let's see the progress. As a little info, if you intend to do a 8,000 rpm tach get that first before you modify your cluster lens.
68c10airstream is offline   Reply With Quote
Old 10-06-2017, 02:58 AM   #3
Curtb1971
Curtb1971's Avatar
Re: Speedeometer
Ahh, definitely. I built my electric speedo cluster then thought man I should have done a 8k tach but after all the work in the lens I think I'll just stick with the 5k on this one but.... may get a wild hair to build another with the 8k
Curtb1971 is offline   Reply With Quote
