Old 10-28-2003, 05:20 PM   #1
supermaxxbasher
what are you guys running on the strip
I would like to see what yall trucks can run in the 1/4. I plan on a 400 horsepower 355 SBC. what kinda time could I see with a 81 chevy short bed.
supermaxxbasher is offline   Reply With Quote
Old 10-28-2003, 05:22 PM   #2
cochino12
It followed me home?
cochino12's Avatar
My times suck and still cant figure out why. 15.4 cant remember what mph. I guess thant mile high air really kills it.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-28-2003, 05:50 PM   #3
gldevall
gldevall's Avatar
Check out my sig.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 10-29-2003, 03:08 PM   #4
Dirty Dan
Oh Look Out!
Dirty Dan's Avatar
I'd probably run 17's or so, until I get a 502, and a turbo. Has anyone done that on a 73-87?
Dan's Webshots
"I have a lot of growing up to do...
I realized that the other day inside my fort" - Zack Galifianakis.
Dirty Dan is offline   Reply With Quote
Old 10-29-2003, 03:25 PM   #5
kevhill85
91 SWB 383
kevhill85's Avatar
i run a 7.91 in the 1/8 sat . i could not hook up . the track was cold .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 10-29-2003, 03:28 PM   #6
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
If I get my truck back cheap enough I will let you know... I wanna run it before the year is over..but I will have to bribe the track officials...since I have no door handles.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 10-29-2003, 03:31 PM   #7
kevhill85
91 SWB 383
kevhill85's Avatar
yes they do . they gave me a hard time about it sat .
Old 10-30-2003, 12:10 PM   #8
supermaxxbasher
would it be possible to get one of these trucks into the 13 second quarter.
Old 10-30-2003, 01:02 PM   #9
gldevall
gldevall's Avatar
absolutely. I've seen street trucks run in the 12's.
Old 10-30-2003, 01:19 PM   #10
Prerunner1982
Prerunner1982's Avatar
theres a longbed with a 505 here that runs 11s. a buddy of mine with a 400, runs 12s. so yes it can be done. if i were to run it would be about....... 18s..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-30-2003, 01:43 PM   #11
cochino12
cochino12's Avatar
Originally posted by gldevall
Check out my sig.
whats the elevation out there? Wonder how much difference it really makes. As you may be able to tell I'm a bit disappointed with my e.t.s
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 10-30-2003, 02:14 PM   #12
gldevall
gldevall's Avatar
I'd say the track is at sea level. The thin air up there would have alot to do with it. You should be able to find a calculation to correct the time for altitude.
Old 10-30-2003, 03:47 PM   #13
low 84
low 84's Avatar
i've seen a 9 second truck run on the street. its a early 90's truck though. and mark dirves his on the street and he runs 9's. so i don't thisnk 13's would be a problem
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-30-2003, 04:02 PM   #14
LOHRTBT
LOHRTBT's Avatar
No offense to Mark but I seriously doubt his truck runs 9's, Its not even caged...I honestly think with SLicks, his truck would tear its self apart on a dragstrip without a cage. I could be wrong but it takes a MONSTROUS amount of power to put a 4000 lb truck into the 9's
Has Mark ever run it yet? DD does not count
~Dave~
Old 10-30-2003, 08:50 PM   #15
low 84
low 84's Avatar
mark said he has run it and that it runs 9's. the other local truck that runs 9's is caged and on slicks though and he drives it all the time. and its a small block, lol. and a "little" no2
'05 1500 Crew Cab
RIP
Old 10-30-2003, 09:01 PM   #16
phantom dually
Project92 SWB stepside
phantom dually's Avatar
getting into the 12's should be easy as long as you have a good amount of torque. I recently made a 1/4 mile pass in my buddys stock ws6 and ran a 12.89 first pass.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-30-2003, 09:47 PM   #17
1FaastC10
1FaastC10's Avatar
i've got a buddy who used to have a '70 C10 SWB completely stripped, 4.10s, ungodly stall converter, and a mild 406. 11.00s werent a problem for him. he sprayed it a few times, then had an N2O backfire and burnt the truck to the ground.
1FaastC10 is offline   Reply With Quote
Old 10-30-2003, 09:58 PM   #18
Russell
Professional Grade
Russell's Avatar
haha, if I were to take my truck to the track right now, not only would they not let me on the track for having such a crappy running engine, but if they did It would probally take me a good minute to get my truck across the 1/4 mile point :P She has absolutely no power right now due to some insanely messed up vaccum stuff
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-30-2003, 10:38 PM   #19
gldevall
gldevall's Avatar
It's about time to go back to the track. I think I will go on a Friday night this time when they have the bracket racing. I think with the cooler weather and opening the exhaust I should be able to get a 14.6?. But I won't be able to go until after Thanksgiving.
Old 10-30-2003, 10:41 PM   #20
ocbaud
Garage Queen Material
i guess a low 17 or high 16 w/ the 305
with the new engine i want to run mid-low 13's
ocbaud is offline   Reply With Quote
Old 10-30-2003, 11:22 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
In the 1/8 or 1/4? I would have to see some time slips to verify that he's running 9's in the quarter...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-30-2003, 11:39 PM   #22
low 84
low 84's Avatar
who mark or the local guy? if your talking about the local guy then it is in the 1/4. i've seen him race known 10 second ls1 on the street and hag right with it only spryaing his first stage. he has 3 stages. he is spraying around 500 hp over what the motor is making n/a. using a plate and fogger system. i have no doubt the truck runs 9's. dallas street racers don't screw around
'05 1500 Crew Cab
RIP
Old 10-31-2003, 12:40 AM   #23
C-10volvo
C-10volvo's Avatar
i dont even want to know how slow my 305 is. i bet you I will still be in second gear as i pass the 1/4 mile mark.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 10-31-2003, 01:48 AM   #24
crackajacka
Stylin
crackajacka's Avatar
i have no clue about mine but i felt my old 305 at least had some get go in it
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-31-2003, 04:09 PM   #25
Tracy Focht
Tracy Focht's Avatar
mine used to be fast...
Tracy Focht is offline   Reply With Quote
