Old 10-05-2017, 05:40 AM   #1
kikkegek
kikkegek's Avatar
height of transmission tunnel C10 and C20
guys,
help me out. a friend of mine and me are both doing a TH400 to 4L80E swap in our Suburbans.
both have 454 big blocks and are original 2WD, automatics (TH400) and were stock before we started on the conversion
he finished his C20, just moved the crossmember back a little, shortened the driveshaft and had no problem fitting the 4L80E under the transmission tunnel.
when I tried to install the 4L80E back on the crossmember that I moved back I hit the bottom of the cabin before I could get it up on the crossmember.
we did a lot and I mean a lot of comparing the last few days.
- cabin bushings are the same
- engine mounts are the same
- crossmember is at same height compared to the frame/chassis
to come to the conclusion that the transmission tunnel of my C15 is just not as high as his C20. his is about 3 inches higher above the transmission.
did anybody else have the same experience? maybe some GM technicians on here that can confirm?
I am going to cut up the transmission tunnel tomorrow and raise it, just curious if somebody can confirm and did the same swap?
this is the link to my project page: https://www.facebook.com/77suburban/
this is my 77 GMC C15 Suburban "STORM"
kikkegek is offline   Reply With Quote
Old 10-05-2017, 06:29 AM   #2
andrewmp6
Re: height of transmission tunnel C10 and C20
The 4x4 trucks had a taller trans tunnel and i think the sticks did also if i remember right.Yeah you can cut out a tall tunnel and weld it in yours or maybe screw or bolt it in depending how you cut both.
andrewmp6 is offline   Reply With Quote
Old 10-05-2017, 07:19 AM   #3
Tiger Joe
like said, 2 trans tunnels used low hump and high hump.
high hump was stick and 4x4.
easiest way to tell if the high hump is removable. low hump is not
Tiger Joe is offline   Reply With Quote
Old 01-17-2018, 06:06 PM   #4
kikkegek
kikkegek's Avatar
I ended up cutting up the tunnel, because I measured everything twice and it just didnt fit....
https://photos.google.com/album/AF1Q...z2c38izwM?.jpg
https://photos.google.com/album/AF1Q...i0Bn_C2cb?.jpg
https://photos.google.com/share/AF1Q...nhtaklR%3F.jpg
final result of my project can be found on my Facebook Project Page:
http://www.facebook.com/77suburban
