Intake Manifold Gasket Gone Bad Symptoms
Does anyone know the symptoms of a intake manifold gasket going bad
Smoke Tires Not Drugs ![]() |
Re: Intake Manifold Gasket Gone Bad Symptoms
Lean codes usually will set at idle when cold. Also a high idle speed. They seem to really show up at start up in the morning. What symptoms do you have?
![]() Join Date: Sep 2005
Lean codes p0300 random misfire code rough idle when cold and so on
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Runs lean, po300 codes, rough idle almost bad enough to stall, mine got so bad that I heard a whistle.
Oil looks like a milkshake from coolant getting mixed in.
2006 Sierra RCSB V6 5 Speed RWD. |
If its a ls 4.8 5.3 or 6.0 no coolant though intake
