Vintage Air heater
The weather is getting cold so I had my heater running the other day and all seemed fine. When I got back and turned the ignition off the heater fan kept going. I wired the heater the way Vintage Air showed in their manual, which was to hard wire the heater, but I decided this wasn't going to work. I had plenty of Bosch relays from another project and wired one in. The relay is controlled by the ignition and now shuts down the heater. It is alot better to turn off the key and not have to shut down the heater, at least to me it is. Here is the diagram I pulled off the internet and a few pictures of the relay mounted on the firewall.
![]() Join Date: Aug 2010
Re: Vintage Air heater
What were they thinking !
Why would they want you to have to shut down the heater separately ? Great fix using a relay!
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
![]() Join Date: May 2007
I installed a VA mini system recently and it has a wire with a CB for the battery and an ignition wire also, might be a later change but mine was made to turn off with the key.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
I put a VA system in my Corvette and I don't remember having to use a relay. VA didn't have a system made for the 1977 Corvette, so there were a few "other" problems with the installation. They had to send me another circuit board to get the controls to work, which was a study in frustration, and I also ended up hard wiring the lights because they never did work proper wired into the VA system.
I actually debated back and forth on buying the heater from VA because of all the problems I had, and I also didn't install an air conditioning unit in the truck because of all the problems I had with the Corvette install. |
wow, my experience was the exact opposite. everything wired up correctly and works right on my install. sorry to hear of your troubles!
