Old 10-06-2017, 12:56 PM   #1
Cooper197
Cooper197's Avatar
Air Vent Block Off
I've been doing some searching but haven't stumbled upon a block off plate for the kick panel air vents on our trucks.
Does anybody know of a vendor that makes them?
Cooper197 is offline   Reply With Quote
Old 10-06-2017, 01:14 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Air Vent Block Off
I have never seen them aftermarket.
16 Gauge sheet metal from home depot and a pair of sheers. A drill for the holes. Use the original unit for a pattern.
Old 10-06-2017, 03:52 PM   #3
72cs20
Vintage Air has them. I blocked off both of the kick panel vents when I put the VA in my truck.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 10-06-2017, 04:04 PM   #4
Cooper197
Cooper197's Avatar
Thanks for the responses guys! I'll check into the ones from Vintage Air, otherwise I'll make some!
Old 10-07-2017, 11:21 AM   #5
The Rocknrod
Moderator
Once you cut them with sheers you take a ball peen and hammer around the edges to flatten it. Then use a Makita 4 inch with a wheel or flapper to smooth out the edges. Prime and paint the backside at least before install.
Old 10-07-2017, 01:56 PM   #6
62 Barnfind
62 Barnfind's Avatar
I made some and added speakers.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
