Old 10-07-2017, 02:33 PM   #1
damnyankee36
damnyankee36's Avatar
Heater Box Rebuild
On the defroster diverter plenum can anyone identify a good replacement for the valve seal? It's a fuzzy, jute of some sort but I don't think it's like on the backs of carpet.
Thanks!
damnyankee36 is offline   Reply With Quote
Old 10-07-2017, 02:48 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Heater Box Rebuild
From where I'm sitting it looks like 3M scotch-bright or a piece of home filter material.
Old 10-07-2017, 03:19 PM   #3
'63GENIII
'63GENIII's Avatar
Couple of pieces of scrap felt worked on mine.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-07-2017, 05:11 PM   #4
damnyankee36
Thanks guys. I just realized that this isn't really being used a seal but more of a pad to keep the noise down when the valve is opened and closed.
I just re-stapled a piece of 1/8" foam rubber to the valve. Works like a champ.
