10-07-2017, 03:28 PM | #1 |
84 C10 Frame Powdercoat Question
I'm planning on sending an 84 short bed frame out for powdercoat. Should I remove the front suspension crossmember and have that coated as a separate part?
Any advice before I send it out would be appreciated. Thanks
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
10-07-2017, 04:24 PM | #2 |
Re: 84 C10 Frame Powdercoat Question
I powder coated my frame and I removed all the crossmembers except for the rear xmember (which I should have) and had them powder coated separately. That way I wouldnt have any rust under those areas. But I didnt removed every riveted piece, such as the body mounts and leaf spring hangers. Looking back I should have done that. Other than those two items everything was removed and then bolted back on.
Paul |
10-07-2017, 04:46 PM | #3 |
How do you like those cpp uppers and lowers? Are those for coil springgs??
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II Last edited by LDO; 10-07-2017 at 04:59 PM. |
10-07-2017, 05:01 PM | #4 | |
Paul |
10-07-2017, 07:30 PM | #5 |
When I had the one I'm working on powder coated, I pulled the front cross member off, and had all the front suspension coated separate.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
