![]() Join Date: Jan 2008
upper trim long box to short box
Has anybody cut down the upper box trim from lwb to swb?
Thanks |
Re: upper trim long box to short box
Its not that hard but it is time consuming. You will have to file and whittle a wood buck that fits inside your trim piece to perfection. Then cut the trim and put it on a hard surface, supported on the entire length, and dolly the end until the shape is suitable. 1200 grit and a little spray primer to find your highs and lows and tap them out on a piece of flat stock edgewise in a vice. Its cheaper to buy repops if you count your time, but that kind of stuff I like to do. Paitence
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Yes, cut it and save the factory end, and backing plate. Splice together and you are done.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
