Old 10-28-2003, 06:56 PM   #1
78' Silverado
\/ My Loves \/
78' Silverado's Avatar
Turning Signals out.....Any Suggestions
Well...I went to Autozone today and got a new Flasher Fuse....and that didnt help so wat yall think the problem mgiht be? Will one bad bulb make all the other ones not work? Anwyas...any suggestions would help me. Thx guys!!
78' Silverado - Blue - (In a Coma)
04' Silverado -Red-
383 Stroker in progress for the 78'!!!
78' Silverado is offline   Reply With Quote
Old 10-28-2003, 07:33 PM   #2
Russell
Professional Grade
Russell's Avatar
Nope, sounds like a wire got finally rusted out somewhere... Check all your grounds, and make sure that all the incoming lines arn't damaged... I gotta tear up my electrical right away to find out why I haven't got any reverse lights...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-28-2003, 08:03 PM   #3
78' Silverado
\/ My Loves \/
**FIXED**...I when i was looking on my fuse panel. I saw where my flasher fuse was...but I didnt notice my Turning Signal fuse. Well I look in my VERY old owners Manual...Can u believe i actually have one haha. Anyways..I found the fuse and it was busted. Lucky me I had a box or 8, 15 amp fues in my truck. Plugged her ni an i was good to go. Now I mgiht just pass inspection ...maybe :P
04' Silverado -Red-
Old 10-28-2003, 08:14 PM   #4
Russell
Professional Grade
Russell's Avatar
Find a mechanic that you know personally, that helps you out a bit
