Old 10-07-2017, 08:44 PM   #1
Drummerboy
Drummerboy's Avatar
Easiest way to upgrade rear from 6 to 5 lug?
I'm going to do a power disc brake on my '68 and can't decide if I want to leave it six lug or convert it to five. If I go five I have to do the rear too. What's the easiest way to achieve this?
Drummerboy is offline   Reply With Quote
Old 10-07-2017, 09:01 PM   #2
Steve Cole
Re: Easiest way to upgrade rear from 6 to 5 lug?
You can change the rear axles and brake drums (at least $300) or you can remove the axles, press the lug bolts out, weld up the holes, and re-drill for a 5 lug pattern and then do the same for the brake drums or buy new drums. There are a few companies that sell kits to do this, I believe CPP does. If you decide to stay 6 lug, I have some almost new 6 lug rotors I will sell for $75.
Steve Cole is offline   Reply With Quote
Old 10-07-2017, 10:20 PM   #3
In The Ten Ring
Easiest way? Buy a 1971 or 1972, then you get disc brakes up front also!
You did not specify.....
In The Ten Ring is offline   Reply With Quote
Old 10-07-2017, 10:52 PM   #4
Steve Cole
Forgot to mention, you can change the rear end to a 71-72 but they are wider so your rim choice would have to compensate for that if you want to keep the wheels in line.
Old 10-07-2017, 10:54 PM   #5
TXgearhead67
I just did this and bought the CPP axle kit. $300 something I believe and it was easy! I am a machinist and welder and would not recommend welding axles. The material is a hard heat treated alloy that needs a specific preheat and post heat to maintain integrity. I'm sure some have done it and got lucky with the results but it's not worth it to me. Besides I bet by the time you weld it and pay for the redrilling of axles and drums it would be close to the same price as new stuff. My 2 cents.
TXgearhead67 is offline   Reply With Quote
Old 10-08-2017, 09:59 AM   #6
Steve Cole
I don't recommend welding and re drilling either, but several folks on a budget have done it. The welding is just to fill in the old holes so you could just leave them open. Personally I just bought the moser axles and new drums. Like TXgearhead said, it's not worth the trouble.
Old 10-08-2017, 10:21 AM   #7
leddzepp
Moderator
leddzepp's Avatar
I did a disc brake conversion on my 68, converted to 5 lug as well. I just swapped in a 72 rear end to match...was very easy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 10-08-2017, 12:59 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
http://www.moserengineering.com/axle...spline-65.html
This is what I did when I first swapped to 5 lug. Summit Racing carries them too. I swapped to discs at the same time, but if I was using drums, I'd just drill the 5 lug pattern. If your drums are already worn some, obviously you could just buy new 5 lug drums.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
