Bed wood bolts. HELP!
I'm changing out my bed wood, all the small bolts in the field came out fairly easy or broke off. The larger bolt around the perimeter are proving to be a real pail in the a**. Have you guys found a better way? I've sprayed pb blaster, and still no dice. If I'm gonna have to grind or drill all of these, I'm gonna lose it. Thanks in advance.
Re: Bed wood bolts. HELP!
If you are changing all the wood, sawsall is the way to go, I had mine out in no time!
Jim |
![]() Join Date: Jun 2009
Instead of trying to loosen take an air impact or electric and tighten until they snap. This is how I did my stubborn bolts.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Moderator
![]() Join Date: Jun 2017
Using a sawsall with a wood blade, cut the wood away a little distance away from the flange, then cut the old wood away from under the flange...
Change the sawsall blade to a metal one and come in from outside into the old wood and cut the bolts off... Be careful to keep accurate pressure so you dont cut the flanges of the bedside... Once the wood is out, just cut the bolts in half from under the flange... ![]() ![]() ![]() |
Moderator
![]() Join Date: May 2007
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I was able to do this with the bolts in the strips. I tried it on the outside bolts, all it did was spin the bolt in the bed side. Which ruined the square hole.
Moderator
Time for a sawsall then...
harborfreight https://www.harborfreight.com/power-...saw-61884.html best $ 30 you will ever spend...just make sure you get wood and metal blades... ![]() ![]() ![]() |
