10-08-2017, 12:34 AM | #1 |
Vacuum advance missing from distributor
1984 C10 305 700r4 trans
No history, trying to get it back in order. Changed fuel pump, thermostat, flushed coolant, changed oil... trying to work on vacuum lines now I'd like to remove all vacuum lines possible, I assume I need brakes, PCV and vacuum advance.... don't see the vacuum advance lol Not sure what the broken tube in photos is, want to put a filter on intake air valve cover... some vacuum lines run into themselves, maybe that's the wipers.... if anyone could help me figure it out be great
2002 Mustang GT Convertible (Mineral Grey) 2003 Mustang GT Convertible (Triple Black - wife D/D) 2013 Ford F550 XLT (Tow Truck - my D/D) 2006 Kawasaki Vulcan 750 1984 C10 Custom Deluxe |
10-08-2017, 12:40 AM | #2 |
Re: Vacuum advance missing from distributor
The broken hose is your gulp valve for your smog pump air injection system
No vacuum = computer controlled, but you eliminated the feedback from the original carb by putting on a non-computer controlled carb. You need a HEI with vacuum advance now |
10-08-2017, 02:18 AM | #3 |
Truck runs fine, sure 84 is computer controlled and someone didn't just remove the vacuum advance from distributor?
