Old 10-08-2017, 04:07 PM   #1
coody
replacement frame on a 56 chevy truck
after reading some past threads. Thinking of replacing my frame on the 56 Chevy truck. Found several rust holes under cab. Also someone before me installed or tried to install a La saber front clip not a good job. After seeing the rust am open to suggestions what other years fit the 56.thinking a virgin frame were I can you my own work. Thanks
coody is offline   Reply With Quote
Old 10-08-2017, 05:24 PM   #2
lynx5653
lynx5653's Avatar
Re: replacement frame on a 56 chevy truck
55 - 57 frames are the same. 58-59 are longer in front by like 2 inches.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 10-08-2017, 06:03 PM   #3
dsraven
the frames are actually pretty flat and straight forward so if you plan on cutting the front off for a new clip and also cutting the rear for putting a big c notch in then you might as well just fab a whole new frame with the width you need.otherwise you end up with a new (used) front part, an old middle section, and then a new rear part.
what are you trying to end up with as an outcome? stock height, low rider, slightly lowered, just power steering and brakes with IFS up front and decent rear suspension?
Old 10-08-2017, 10:35 PM   #4
coody
I have a 72 firebird subframe I want to put on it.lower a bit, have a late model Camaro disc brake rear end. triangular four link for starters
