10-09-2017, 02:57 AM | #1 |
Anyone using ididit steering columns with original steering wheel?
The PO of my truck installed an Ididit column and some funky steering wheel. Just wondering if the original steering wheel will fit on the column. The Ididit website says 69-94 GM passenger steering wheels are bolt on, but doesn't mention anything about our trucks.
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
10-10-2017, 01:24 PM | #2 |
Re: Anyone using ididit steering columns with original steering wheel?
I have a 66 C10 with the Ididit Retrofit tilt column. Original Deluxe steering wheel fits perfectly.
10-10-2017, 06:18 PM | #3 |
I don't have an Ididit column but an original 72 column and my 65 deluxe wheel fit on it.
10-10-2017, 07:38 PM | #4 |
It's Better With Nitro
Ididit column with deluxe steering wheel (diameter reduced).
10-12-2017, 12:25 AM | #5 |
Location: Coderre, SK. Canada( really close to nowhere)
10-12-2017, 05:46 AM | #6 |
Moderator
This used to be a great thread on cutting down a steering wheel, starts on #211:
http://67-72chevytrucks.com/vboard/s...=474456&page=9 Here is one that still has pics: http://67-72chevytrucks.com/vboard/s...d.php?t=457422 Restoration Kit: http://www.eastwood.com/master-steer...w-instruc.html Or you can have someone else do it: http://www.steeringwheelbob.com/ http://qualityrestorations.com/
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-12-2017 at 06:32 AM. |
10-12-2017, 06:32 AM | #7 |
Moderator
For aftermarket columns:
https://brenttsbrackets.weebly.com/s...customers.html La Zona - If you buy an Ididit you'll want to make sure you buy a column for our vehicles: http://www.classicrods.com/compare/2549/2554
10-12-2017, 09:48 PM | #8 |
Vin, is that an actual stock wheel reduced? or a reproduction wheel? only asking because i have the same factory wheel but the horn ring has been broken off since before I've had the truck and id like to find a new one but not having any luck!
