Old 10-09-2017, 08:22 PM   #1
Jered1987
Jered1987's Avatar
Tire replacement
What size tire can I replace a set of 255 85 16r with they seem to be an expensive size. It's on a 86 k10
Jered1987 is offline   Reply With Quote
Old 10-10-2017, 07:58 AM   #2
cadillac_al
Re: Tire replacement
You must have aftermarket rims. 255/85r16 is about the perfect size for these trucks but 15's are cheaper. 16's are usually 10 ply so they cost more.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-10-2017, 01:01 PM   #3
Jered1987
Jered1987's Avatar
My wife's grandfather built the truck a lot of stuff has been changed on it and a lot of different years of parts into it. I think the engine and trans are out of a 76 Camaro. The drivetrain is a 85. The engine has had all emissions removed and all electronics taken off. For some reason he did away with the hei I guess . It doesn't run right as it won't idle without feathering the gas and that's even with it warm. The windshield wipers won't work there's a bit to do.
Old 10-17-2017, 10:32 PM   #4
tucsonjwt
I have 235/85R16 on my 83 C20, so I don't know about a K10, but I recently got some 225/70R16 for the front of my truck and I did not realize what a difference there was in just a few numbers. The front tires lower the truck about 1.5-2 inches in the front. Reminds me of high school.
tucsonjwt is offline   Reply With Quote
Old 10-19-2017, 07:17 PM   #5
LT7A
You can use an online "tire size calculator" to determine what you want: taller/shorter, wider/narrower and then search for that size and see what comes up. Seeing what tirerack and discounttire have give you an idea of what's standard and what's oddball. For instance, I recently found that what seems like an oddball size 255/55 r18 is fairly common and not expensive since many manufacturers make them -- stock size on the BMW X5 I guess.
