Old 10-09-2017, 09:54 PM   #1
SunSoaked
SunSoaked's Avatar
Cucv axles swap-k20, brake concern
In the process of swapping 14ff/Dana 60 into my 85 K20. I spec'd a new m/c for the k30. I'm wondering if the combination valve located on the frame horn cross member needs attention? Anybody have any input on this? Appreciate the help.
SunSoaked is offline   Reply With Quote
Old 10-10-2017, 08:00 AM   #2
cadillac_al
Re: Cucv axles swap-k20, brake concern
I put a Dana 60 on my 76 K20 and didn't do anything with the brakes. Same master and combination valve and it works fine.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-10-2017, 12:21 PM   #3
Ziegelsteinfaust
The cucv likely used hydroboost. Which can be a better brake system since it allows more pressure to be applied.
Like stated above you do not need to switch anything more to make the set up work.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-10-2017, 12:59 PM   #4
sweetk30
sweetk30's Avatar
as said it can work .
but to be 100% correct the 1/2 and 3/4 ton calipers are smaller piston size over the 1ton dana 60 size . so they require more volume of fluid .
lots have gotten away with this swap and been happy . and lots have not been happy .
if you can get the hydroboost parts and brake pedal and the lines and pump from the doner truck and swap them in . you will like the hydroboost better over vac brakes .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-10-2017, 01:35 PM   #5
SunSoaked
SunSoaked's Avatar
Thanks for the info. I'm doing major conversions on the truck over the next few months. Stage one is the axle swap, then the hydroboost, serpentine setup, edelbrock pro-flow and the nv 4500/205 swap. I have the hydroboost/hydraulic pedal assembly as well as the manual trans/tilt steering column ready to go (driveline mods tbd).
Regarding the brakes- I was just wondering if that valve would affect the bias of the brakes, assuming it's even different between a K20/30? I assume it's a combination valve (proportion/pressure loss warning) thing. Looking at it the other way-if I put the K20 valve in a stock cucv, would it have any effect?
