Old 10-09-2017, 10:36 PM   #1
RedRider
RedRider's Avatar
Lower control arm: what is this and can I fix it?
1970 C-10 2WD
Spent last weekend cleaning up the control arms for my disc conversion install. My wire wheel accidentally damaged this soft piece on the rear side of the lower control arm:
First question: What is this? I'm guessing the rubber grommet (rear #27 in the diagram).
Second question: Any way to fix/repair it? Looking for a mid-term solution that doesn't involve taking the control arm off. Doesn't have to be pretty, I just don't have it in me to tear everything apart again. Thanks!
RedRider is offline   Reply With Quote
Old 10-10-2017, 08:20 AM   #2
Project86
Re: Lower control arm: what is this and can I fix it?
looks to be fine.
only way to fix/repair it, is to replace it. all it is, is your lower control arm bushing
Project86 is offline   Reply With Quote
Old 10-10-2017, 09:44 AM   #3
RedRider
RedRider's Avatar
Originally Posted by Project86 View Post
looks to be fine.
Thanks. My initial impression was to leave it alone. There doesn't appear to be any grease leaking out or anything, although the lower inside control arm doesn't have a grease zerk.
Old 10-10-2017, 11:42 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Its a dust shield/grease holder inner.
These rigs don't necessarily have control arm "bushings". The have large shafts that have large "caps" that screw onto the end of the shaft and into the control arm at the same time.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
