Old 10-10-2017, 09:07 AM   #1
Stephenshane237
repop inner cowl replacement help
I am replacing the inner cowl panel on my 1969 c10 and just wondering if anyone else has had a similar problem. The drivers side fitment does not look like it will get down enough, passenger side is great. I am concerned about the rest of the panels lining up if I mount it this way. This cab is my first attempt at metal work and not sure where to go from here.
Stephenshane237 is offline   Reply With Quote
Old 10-10-2017, 11:05 AM   #2
dfraze
Re: repop inner cowl replacement help
I had the same problem with mine, which was a triplus from AMD. I found that the flanges were not bent to 90°, took a hammer and dolly to them and fix them right up. The cowl mounted up fine.
dfraze is offline   Reply With Quote
Old 10-10-2017, 12:09 PM   #3
Stephenshane237
Thanks I assume you are talking about the flanges towards the front of the firewall correct ?
Old 10-10-2017, 03:19 PM   #4
dfraze
Yes sir,
also I notice the radius of the two is different. Your new panel radius is larger than the original. Which could have something to do with the length issue. Good Luck
