What size lowering blocks to use?
I have a bolt in c notch and I ordered a super track bar already. I have the shock relocating brackets and I'm running bags. I want to order some blocks so that I can run more air in the bags but I cant decide whether to run 1.5 or 2 inch blocks I'm more than likely gonna run 15 inch wheels. Any input?
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
Re: What size lowering blocks to use?
I think 1 inch might be your limit as you said you were running 15 inch wheels. If you go 2 inches your axle bolts might be below your scrub line.
Thanks.
Moderator
![]() ![]() Join Date: Aug 2011
The scrub line. There are those who tempt fate. But it can be an expensive attempt.
![]() Join Date: Jan 2011
I have 1 1/4" blocks in mine with 3 degrees machined into the top to correct the pinion angle. The blocks move the rear forward thats as tall as I wanted to go and also keep the scrub line intact.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Where did you buy them from if you don't mind me asking.
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
Moderator
CPP sells them:
http://www.ebay.com/itm/64-65-67-68-...19.m1438.l2649
It's Better With Nitro
I run a 2-inch block...it's close but the tubular trailing arm mount clears.
I machined mine.
Jimmy
Ok, so question on this. I am getting a set of 02 wrangler rear springs, and have a 2 inch block of steel that I will throw on with custom U bolts. With the amount of drop this will give me, should I be using an axle shim??
![]() ![]() Join Date: Jul 2002
I have heard from the folks that used them is the wrangle springs are too soft. they really don't support the truck well even with an empty bed.
I have TJ Springs and they are coming out this winter. Limit's hauling even one or two buddies at a Car Show. I am going with the correct lowered springs.
