Old 10-10-2017, 01:46 PM   #1
Bpilcher72
Bpilcher72's Avatar
Instrument Cluster Hardware
I am looking to replace the J-Nuts on my instrument bezel with threaded rivet inserts. I am trying to figure out what the dimensions are on the screws that mount the instrument bezel to the dash. Anybody know the dimensions on those?
Bpilcher72 is offline   Reply With Quote
Old 10-10-2017, 07:16 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Instrument Cluster Hardware
They are #8 x 7/8" pan head screws
The whole idea of the "J" nuts is so there is some movement in them so the screws are self aligning. If you use inserts you will have no movement and if you don't have them perfectly aligned you will probably crack your bezel tightening the screws up. Just a thought.....
LockDoc
Leon
