10-10-2017, 03:45 PM | #1 |
Timing for a 383?
Can you guys please let me know what you set your timing at with a 383 stroker. Having a little overheating issue so was just wondering if maybe my timing is way off. Thanks.
10-10-2017, 03:47 PM | #2 | ||
"I ain't nobody, dork."
Re: Timing for a 383?
Depends on the cam.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-10-2017, 04:06 PM | #3 |
Mine = 12 initial 32 @ 2800
Stan 67 swb BLU MULE posted via flip-fone |
10-10-2017, 04:39 PM | #4 |
Mine likes 14 initial, 34 total, with a heavy advance spring kit. it's a 10:1 motor, alum heads, about 230 degree cam on a 110 LSA.
But as suggested above it has everything to do with cam, compression, head material and design, etc. I would recommend starting low (about 10 initial, 30 total) and creeping up on it. If it doesn't run better with more timing, there's no reason to add it. total timing is more important than initial. |
10-10-2017, 06:18 PM | #5 |
Im sorry guys its a guys its running a 10:1 with a 292 cam and old school double hump heads.
10-11-2017, 05:55 PM | #6 |
You using ported or manifold vacuum? Engine will generally run cooler, especially at idle with manifold vacuum.
You sure you are not running lean? Check your plugs. |
10-12-2017, 12:39 AM | #7 |
At the body shop.
My 400's like 12-14° initial and 36-38° all in by 3000 and no vacuum because the intake fitting hits the vacuum pot
" That didnt make it any newer " " Dont antique the equipment " |
10-12-2017, 08:40 AM | #8 |
Vortec heads like 32 degrees total , you dont have those , my 383 with procomp heads and a 270 hr cam like 36 degrees of total timing , 12 degrees initial , it pulls like a train , be carefull you are not lean on fuel either as this can cause overheating , and pinging
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
