upper control arm shaft
has anyone ever changed a upper control arm shaft? mine needs replacing, so i took it apart last night and it seemed to be fairly straight forward. i have heard that you have to be very careful when assembling the new shaft, that there is a certain way to screw the shaft into the end caps, or the end caps onto the shaft,
whatever. as far as i can tell, there is only one way this assembly can go together. tighten one end cap,screw in shaft, then tighten other end cap, am i not seeing something here? seems pretty easy, but then again, it wouldnt be the first time i screwed up something easy, any help here would be great, thanks |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I just did a pair of both upper and lower controll arm shafts for my panel. What I did was to place the shfts into the control arms and turn the nuts on each end an equil amount. Then screwed the big nuts into the threaded holes, periodicly checking to see that the shaft can turn. As long as the shaft can turn there shouldn't be any problems. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
