1972 Heater Control Cables
Working on a 72 and the heater cables are awfully tight to maneuver. Is replacing them a good idea before we bend the levers?
1972 C10 LWB 2WD 307 4 speed Rescued from Field July 2017 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Re: 1972 Heater Control Cables
Your OEMs are much better than re-pops. Pull your glovebox liner (I know) and carefully remove the cables. Hang them up let penetrating oil to run down thru them overnight, exercise them a bit and put them back in. You can do it quicker but I'm lazy. I've already replaced 2 sets of repop cables with recycled OEMs like this.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Florida Edition
Welcome aboard by the way. The levers break easily. Pot metal
OK any good recommendations on oil. Lithium would be too thick i would assume?
Larry
#5 | |
The Older Generation
LockDoc
