Old 10-10-2017, 05:32 PM   #1
Al1940
68 Chevy Truck C-10 327 Replace Alternator Belt
I am trying to put alternator/fan-water pump belt on and power steering pump belt is in the way. How do I loosen/ remove steering pump belt so I can pass between the steering pump pulley and the fan-water pump pulley with the alternator belt?
Thank you,
Al
Al1940 is offline   Reply With Quote
Old 10-10-2017, 06:20 PM   #2
outfield
Re: 68 Chevy Truck C-10 327 Replace Alternator Belt
The power steering pump adjustment bolt is easier to access from under the truck. So grab a flashlight, climb under the truck and look around. You will see the adjustment bolt and the slot it slides in, this will need to be loosened up, you will also need to loosen the pivot bolt that this all pivots on, then you can loosen thing enough to remove this belt.
outfield is offline   Reply With Quote
Old 10-10-2017, 08:59 PM   #3
Al1940
Thank you Outfield, that was easy. Now I've discovered the belt is a skosh short. I loosened alternator and moved it to the left until it hit metal. I removed bottom bolt of alternator, put belt on, then I couldn't put bolt back in and belt was too tight.
I have concluded belt is too short even though this is the recommended belt.
Will call Napa for next size. Any recommendations?
Thank you
Old 10-10-2017, 09:03 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Take the belt to Tractor Supply ....they have belts in one inch increments....
AussieinNC is offline   Reply With Quote
Old 10-11-2017, 09:59 AM   #5
outfield
Smile Re: 68 Chevy Truck C-10 327 Replace Alternator Belt
You will just need to go and get a belt a little longer. I found out when replacing the belts on my '69 that what was recommended was too long... so I needed to go a skosh shorter.
For some reason the computer records for these old trucks are not as accurate as the old book were for parts lookup.
