Watch out for your cornhole !
![]() Join Date: Jun 2003
Who has a big block truck?
I'm wading through this big block conversion. I need pictures of STOCK big block setups in these trucks. I DO NOT need pictures of modified engines. I want to see what it should look like in all it's GM glory. Need pics to see what color stuff should be, what the vacuum hoses looked like, air cleaner, water neck, plug wire routing, everything.
I'd really like to see some pictures from literature depicting these trucks when they were new and unmodified, or at least a decent original untouched truck. Thanks, Kevin
Just like to part out trucks!!
Kevin, on my post about that longhorn is a pic of an original BB 402, it might help you. Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
2A674 Tank Rat
Heres a pic of mine. Hope it helps. If you want a better pic I can try and take some better ones tomorrow after work while its still daylight.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
2A674 Tank Rat
Tx firefighter - The valve covers on mine are blue and the engine is red. It is still stock as best I can tell. I haven't altered it yet.
Thats the Hillbilly way
Don't know if this helps if you need something specific let me know I'll take a pic .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Hey, thanks guys. Keep them coming please. I'm saving these all into a file for reference.
72 LONGHORN OWNER
Big Block
Here is a few of mine..Rebuilt 402.......Longhorn..If you need specific areas just e-mail.........
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
huh ???
Here's a pic that teeitup posted a while back that might help
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
huh ???
and another. Hope you don't mind Randy...
BBB (Big Big Block) (502)
here's another
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
My other Love
just another reason to show off my big block
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Here is a pic of my son's 72 big block, right side.
Jim |
#13 |
Here is the left side.
Jim |
#14 |
2A674 Tank Rat
JimKshortstep4x4 - I noticed that your engine doesn't have the vacuum/electric switch like mine does. I have been trying to find out what the switch is for, what it does, can it be replaced, can I delete it? If anyone knows ............
#15 |
I think that you are talking about the vacuum timing retard setup
and you are right I did eliminate it. (The system is made to not let the vacuum advance work until the engine is warm and the transmission is in high gear). The gas mileage is bad enough without having the vacuum advance not work. Jim |
#16 |
Could someone shoot me a couple of specific pics?
1) low on each side, like down at the motor mounts, p/s pump, exhaust maniflods, and fuel pump areas? 2)the p/s fluid reservoir, where it mounts? Any pics of that? Are the holes already going to be in the fender for it?
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 10-29-2003 at 10:23 AM. |
#17 |
With the engine in the truck getting a meaningful shot is pretty tough as everything blocks what you want to see.
Here is a pic of the power steering bracket mocked up to a block which is upside down. Jim |
#18 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Here are a couple of side shots. It's OE, except for intake and carb (and a few internals you can't see)
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#19 |
Resident Curmudgeon
rh side
