Old 10-13-2017, 11:11 AM   #1
CCCC
CCCC's Avatar
Edelbrock/Carter AFB rebuild kit - need knowledge
As you may know from another thread here, I am climbing out of an ethanol storage mess. I found an ED 1406 carb rebuild kit on Ebay for less than $20 with free ship, and it appears that the same kit will work with a Carter AFB Comp Series carb (# looks like 98053 or similar - might be 960--). .
Will this kit work for both types? Any experience or recc regarding this particular kit by PERFORMANCE OVERSTOCK - they say:
"We are the Largest Carburetor Distributor in the Nation! This is a Upgraded better than OEM CARBURETOR REBUILDING KIT For all EDELBROCK - - -will fit Carter Competition AFB's."
Thanks for any insights.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 10-13-2017, 12:32 PM   #2
geezer#99
geezer#99's Avatar
Re: Edelbrock/Carter AFB rebuild kit - need knowledge
Of course it works.
Edelbrock didn't design the carb. They bought the design from weber. Weber in turn bought it from carter who built the first ones.
Old 10-13-2017, 12:58 PM   #3
CCCC
CCCC's Avatar
Thanks, geeezer. You are my best expert source for such info, thanks to this site.
After running/fixing Quadrajets on my Chevs/GMs for a long time, I am wading into new water because some POs replaced Quads with EDs, AFBs and even a Holley or two on these trucks. Thanks again.
CCCC
Old 10-13-2017, 06:04 PM   #4
mike16
Edelbrocks website will give you alot of good information on rebuilding those carbs and choosing parts to make it compatible with your engine/displacement/cam choice
mike16 is offline   Reply With Quote
Old 10-13-2017, 06:58 PM   #5
CCCC
CCCC's Avatar
Thanks mike16 - that will be helpful.
CCCC
Old 10-13-2017, 09:34 PM   #6
dflarsen77
Active Member
I used Carb Junkies kit on eBay. It came with a metal accent pump, since the plastic ones supposedly don't like new gas. And you can get kits with the floats. L the stuff was great quality, think mine was 40-45 with pump and floats.
They still have it
https://m.ebay.com/itm/Edelbrock-AFB...74?_mwBanner=1
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 10-14-2017, 12:03 PM   #7
NorCalC20LWB
I hope this is not a thread hijack, but where on the Edelbrock website does it say what jet, etc combo is recommended for a particular setup?? I have a 1405 or 1406, can't remember, it's the one with the manual choke, and built my motor a while ago. The only thing I found on their website said something like "to determine what combination of parts to use check your spark plugs and jet differently to become leaner or richer" or something to that affect. Was hoping they would have some sort of graph that showed what combo to use with specific engine specs.
NorCalC20LWB is offline   Reply With Quote
Old 10-14-2017, 01:07 PM   #8
toolboxchev
So I have an Edelbrock on my 350. I also have and old Carter sitting in storage. Luckily I have been able to run E-10 and have not rebuild the carb since new over 8 years ago.
Now when looking for gaskets and accel pumps I would be looking for kits that would be ethanol resistant.
In my manual from Ebrock it says these things can be setup to run ethanol. The only mod I have done so far is replace the springs with the silver, or clear set and I have seen an improvement. Ebrock sent them to me free of charge to help out.
They have excellent customer service.
toolboxchev is offline   Reply With Quote
Old 10-14-2017, 03:31 PM   #9
CCCC
CCCC's Avatar
Thanks all - good thoughts there. I ordered three kits - supposedly ready for ethanol - but may want to substitute in some components as noted above. Kits don't have floats - as far as i can tell from the shake/weight test, the current floats are tight/good.
CCCC
Old 10-14-2017, 05:40 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
1405 is an AFB clone of 600 CFM, manual choke. 1404 is 500 CFM, manual choke. 1406 is 600 CFM, electric choke.
Call the Edelbrock Tech Line and request a copy of the "Performer Series Carburetor Manual". They'll send you one free. The Carb Manual will have those graphs you're searching for.
Old 10-15-2017, 02:08 AM   #11
Rickysnickers
Edelbrock carb manual https://www.google.com/url?sa=t&sour...90x_TyQzXX6B_0
