Old 10-13-2017, 02:13 PM   #1
1968_K20_4x4
K20 rear axle leakage!
Hey all,
So the other day I noticed something was leaking from the drivers side of my rear axle. The truck is a '68 K20 and has the eaton HO52 axle. I noticed something had leaked all over the inside of my rear tire from inside the brake drum. I disassembled the axle and am not sure exactly what the problem is. Is it oil leaking from inside the axle? Could the seal be gone? I looked at the hub spindle and it looks pretty worn down. If so what can I do? Should I try replacing the seal and see if that fixes the problem? The seals were replaced only last year. I thought possibly brake fluid leaking but I do not see any evidence of this inside the hub. How can I tell for sure? I will upload pictures for analysis and appreciate any input on this issue. First picture is what the inside of the tire looked like. Second pic is the inside of the wheel hub/brake drum.
'68 Chevy K20
'72 Chevy K20 - Smokin' Ochre
'08 Mercury Grand Marquis - Daily driver/ Parts fetcher
Ohh uh, I didn't have time to fix everything...
1968_K20_4x4 is offline   Reply With Quote
Old 10-13-2017, 02:19 PM   #2
1968_K20_4x4
Re: K20 rear axle leakage!
Here are a couple of pictures of inside the axle. I have never taken one apart before, but I assume it shouldn't look like oil got everywhere?? lol. When I removed the axle shaft not very much oil drained out, I was expecting there to be more
'68 Chevy K20
Old 10-13-2017, 02:29 PM   #3
B. W.
B. W.'s Avatar
The seal needs replaced. The spindle looks good from the photos. Check the area on the spindle where the seals rides. If it's grooved or damaged you can install a repair sleeve. When the seal is out of the hub, check the bearings & races, they should be smooth & shiny.
B. W. is offline   Reply With Quote
Old 10-13-2017, 02:42 PM   #4
1968_K20_4x4
Thanks for the reply! Any tips on getting the seal out of the hub? Do you have to hammer it out?
'68 Chevy K20
Old 10-13-2017, 02:56 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agree with replacing the seal. I think there may be a tool for removing the old seal, but the few times I have done it, I just hammer it out with a drift.
It's normal for just a small amount of oil to leak from the end of the axle. Check the level when the job is done -- you might not even need to add any.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-13-2017, 03:00 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Looks like that "flange" looking part on the spindle is the other half of the seal stuck on there. The middle part of the spindle isn't used for the bearing to ride on. Only the machined surfaces you see on each side of the "rough" area.
Your drum brake shoes will need to be replaced as well. Once they get gear oil on them, they are toast.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-13-2017, 03:05 PM   #7
1968_K20_4x4
Awesome guys thanks, I checked out a youtube video which was really informative and the guy just gently tapped it out. In the video he mentioned checking the breather tube on the differential to make sure it isnt clogged up because that can cause the seals to leak. I have never seen a breather on my rear axle. Is it there and I am missing it, or do the eaton axles not have this feature? Also since I have the axle apart and my brake shoes are covered in oil I am going to replace them. Can I replace the shoes on the drivers side and not on the passengers side? Or do I need to do both sets?
'68 Chevy K20
Old 10-13-2017, 05:57 PM   #8
mike16
both sides both seals both sets of shoes
and since you have it that far apart you might want to do the wheel cylinders too
and why not flush the differential and splash some fresh oil in it
mike16 is offline   Reply With Quote
Old 10-14-2017, 05:44 PM   #9
1968_K20_4x4
Thanks for the advice, you're right while I've got it apart this far I'm going to do the other side while I'm at it, and also change out my gear oil. Good chance to inspect my rear diff. Picked up new brake shoes and seals today, will be installing them when I get a chance. Any further issues and I'll post on here
'68 Chevy K20
Old 10-14-2017, 08:14 PM   #10
saxart
saxart's Avatar
I've sometimes used the axle to get the seal out. Just before it pulls out of the seal, use it as pry-bar and pop out the seal. Easy!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 10-15-2017, 03:13 PM   #11
CCCC
CCCC's Avatar
Very good info above. Maybe purchase and extra set of those seals if you plan to keep the truck for a while. Use a flat surface driver to install the new seal - I have cut a clean 2X4 to extend beyond the seal casing but well within the drum and use it wide side down - check level often.
Not recommending this, but I was in a pinch and was able to save and re-use a pair of oily shoes by cleaning thoroughly with brake cleaner (more than once) and letting them bake in summer sun for a while. They ran in OK and looked fine when I later had to go in to rebuild a wheel brake cylinder.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 10-15-2017, 08:11 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Since you're gonna change the oil (good idea), you'll be removing the diff cover. Try Permatex 81182 with a gasket to seal it all up. It's made specifically for use with gear oil and has worked well for me.
- Mike -
RIP El Jay
