10-13-2017, 05:02 PM | #1 |
Differences between Edelbrock Performer Intakes
Was fortunate to buy an Edelbrock 3701 for very low dollars, and am wanting to compare it's aspects to a 2701 before putting it to use. Have not been able to find comparative info/specs online. Anyone know about how the 3701 is different from the 2701?
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
10-13-2017, 09:18 PM | #2 |
Re: Differences between Edelbrock Performer Intakes
Google says the 2701 is the Performer EPS intake and the 3701 is an exhaust gas recirculation (EGR) intake.
10-13-2017, 09:27 PM | #3 |
Active Member
3701 is also a spread bore flange, so perfect if you have a quadrajet. 2701 has no egr, but it has a squarebore flange, good for holleys and edelbrock carbs.
David Larsen 1970 Chevrolet C-10 |
10-14-2017, 03:34 PM | #4 |
Thanks Mike and dflarsen - it has the spread bore inlet, which is what I need for the Q'jet, and I think I can defeat the the EGR aspect now that I know what it is. Does that sound correct? Thanks for the info.
