refinishing seat bases(tracks)
whats everyone doing?paint,powder coat,plating?do they come apart?thx
Re: refinishing seat bases(tracks)
I was wondering the same thing. After they are apart what is the best way to get some surface rust off of them without messing up the surface of the tracts?
Moderator
![]() ![]() Join Date: Aug 2011
I used Ospho three coats in fifteen minutes. Rinsed and dried with drier/heater. Only thing I needed to do was then use a satin clear coat on them. But in the track area I used dry lube (spray). My tracks work better than I would have thought.
wow,just googled ospho(never heard of that stuff)great idea!better than blasting.thanks rocknrod
Moderator
Ya, you know just have to be careful with it as it is an acid. Get some cheap 1" or 2" brushes, googles and nitrile gloves. Don't get it on you without rinsing it off right away. At least that's how I deal with it. Results may vary.
Hey rocknrod,I forgot to ask...did you disassemble yours?
Moderator
No I tried on one set and screwed the pooch not sure if anyone has for that matter. The second set I didnt.
![]() Join Date: Feb 2014
