frankenstien Fabrications
Vin Question
I have a question about a vin
1968-69 GMC truck K 4 wheel drive E 8 cyl. 1 1/2 ton O D Wide side Z I have no idea Bruceman1968 has on his page that its a special designation but all i can find is " if theres no special designation" dash is there if not used well mine is a Z what does that mean ? Thank you guys in advance
frankenstein Fabrications |
Re: Vin Question
The fourth & fifth digits should both be numbers. Fleetside designation would be listed in the model number, not the VIN.
the 6th digit is the mfg plant (Z = Freemont) |
Re: Vin Question
Not to high Jack your tread but I to need help with my vin. Hopefully someone can answe both of ours.
C - chevy S - I6 1 - 5 - panel? 7 - 67 0 - D - I have the glove box stating it's the special edition paint code and panoramic. Custom deluxe cab.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#4 | |
Re: Vin Question
The Z is for Freemont assembly plant and A is 1969 or B is 1968. You might not have a dash or space in yours.
CHEVY/GMC VIN DECODERS |
#5 | |
Re: Vin Question
C = 2wd S = I-6 1 = 1/2 ton 57 = 115' WB shortbed OD = wideside bed (Fleetside) EDIT Just noticed you said your SPID stated panoramic. So that means you have a 1967 GMC. CS157OD is both your model number and the first half of your VIN.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 10-15-2017 at 01:17 PM. |
Re: Vin Question
Thanks so it is a GMC. That would explain the leaf rear.
Re: Vin Question
Bought this 4x4 from a neighbor/friend with the intention of restoring it or making a rat rod out of it. He had rolled it a long time ago, and ended up putting a Chevy body on the GMC frame.
this is what the guy told me so is the vin i have the gmc vin or the chevy vin when i crossreferenced the vin on bruceman1968 the chevy vin didnt match up but the gmc vin did
Re: Vin Question
VIN # KE10DZA14615
here is the full vin
#9 | |
Re: Vin Question
Re: Vin Question
Ok You got it. Too fast for me(smile)
Re: Vin Question
oh thanks guys
Re: Vin Question
wait im lost again
K- 4 Wheel Drive E- 8 Cyl. 1-1/2 Ton 0D Wide Side Z-??????? A- Atlanta Vin#-14615 im i reading that wrong ??
#13 |
Re: Vin Question
Yes look again,
Z = Fremont assembly A = 1969 Edit You should have a space/dash between the O and the Z. If not no problem just disregard the space/dash. The Z is your assembly plant code.
#14 |
Re: Vin Question
Ok thanks guys
