10-15-2017, 03:41 PM | #1 |
Compressor fo overload bags
Overload bags on my lowered Suburban. I like to keep 15-20 lbs in them just because it rides so much better with just a little air in them. Occasionally I do carry a load or tow with it and add more but it's not that often.
It currently is manual fill and of course leaks down over time. I am looking at adding a compressor on a frame rail and for my low volume air usage wondering if I can get by without an air tank and just use the compressor to fill the bags? Obviously the volume of air I need is small but not sure if the volume of the typical compressor is adequate. Have tossed around the idea of putting a pressure switch in the line so it keeps the bags at the pressure I like. Then putting a manual switch inside for when I need more air for a load I could turn on the pump and raise the pressure. Am I missing something? |
10-15-2017, 03:57 PM | #2 |
Post Whore
Re: Compressor fo overload bags
I keep one of those small 12v compressors behind the seat...plugs in cigarette lighter...I looked into adding one of those tank style but its a lot of expense for no more than I'd need it...
10-15-2017, 10:50 PM | #3 |
Check into late80:s cadalic or lincon with level ride control.I took one off ofa caddie drivers side inner fender under hood and it was half the size of a old cigar boxif you know what I mean.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
10-16-2017, 08:53 AM | #4 |
