Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-18-2017, 01:40 PM   #1
Hosedragger622
Can i ask a dodge truck question
My sons truck, 1996 1/2 ton p/u with 318 motor, upper radiator hose blew off t-stat hosing, hose still good and clamp still intact, any possible reason for this besides loose or bad clamp? Any help would be appreciated, thanks.
Hosedragger622 is offline   Reply With Quote
Old 10-18-2017, 01:47 PM   #2
Coley
Coley's Avatar
Re: Can i ask a dodge truck question
Is the truck and its hose and cooling system fully original?
in other words are all the hoses connected to the right heater and bypass points?....or have any of the hoses being re-routed due to a heater core failure or whatever else reason?
Have you checked the thermostat to make sure it is functioning correctly?...I think it would normally be found inside the t-stat housing. Its easy to check....remove it and put it in a pot of boiling water....it should open up.
Water is not compressible, so if it can't get through somewhere....then the pressure that will build up behind increases...a lot and it will blow through something.
my two bits...so far
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-18-2017, 03:47 PM   #3
GR8-68
GR8-68's Avatar
Really you need to use a thermometer to be sure it opens up at the correct temperature, you do not want it opening at boiling point.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-18-2017, 04:19 PM   #4
demian5
demian5's Avatar
Jack up the radiator cap and slide a chevy under it.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-18-2017, 04:32 PM   #5
Wrenchbender Ret
It may be overheating or the pressure cap is defective. More then likely the clamp was not tight.
Wrenchbender Ret is offline   Reply With Quote
Old 10-18-2017, 08:08 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Wrenchbender has the likely culprit, but I like your answer. No mercy in these parts!
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-18-2017, 08:20 PM   #7
toolboxchev
Dont worry about it. Dodge is having a sale on all new trucks, even giving away a free puppy dog with every purchase.
Again dont worry, you will never have to walk home alone again!
toolboxchev is offline   Reply With Quote
Old 10-18-2017, 08:31 PM   #8
Coley
Coley's Avatar
...Again dont worry, you will never have to walk home alone again!
Cruel.....funny!...but cruel.
I'm not a big dodge fan...but they have sure built some good engines.
Coley
2000 Dodge Ram 1500
Old 10-18-2017, 08:50 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Best. Comment. EVER!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-18-2017, 09:02 PM   #10
GR8-68
GR8-68's Avatar
Seeing this has turned into a beat up the Dodge, I drive a 2013 Ram reason being it rides 10x better than the Chevrolet I test drove. To bad they couldn't get their game up on Dodge because I have always been a chevy man, or should I say GM
Larry
"Project 68"
paypal.me/ldgrant
Old 10-18-2017, 09:57 PM   #11
ApacheNick
Hate to be the one to say this, but being a dodge 318 I would be inclined to think cracked head(s).My brother and I have rebuilt a few of these engines (he's a dodge guy) and every one that we've taken apart has had at least one cracked head.They seem to like breaking right between the intake and exhaust valves.
Before I get jumped on for this, every one of these engines was a running engine when we tore them apart.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 10-18-2017, 10:56 PM   #12
Hosedragger622
Thank you for everyones input, we put it back together and he will continue to drive it like a 17 year old will til the next go around. its got 190000 miles on it and has survived his other 2 brothers driving before being a hand me down truck, grand pa gave it to my oldest 5 years ago and its still going for now.
Old 10-19-2017, 03:55 PM   #13
MARKDTN
Does that go with the free heated bumpers so your hands stay warm while you push it off the road?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-19-2017, 09:03 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'm not sure about 1996 but in 200 Dodge went to a plastic clamp system to hold the filler neck in the middle of the hose. I had the original blow apart and then the replacement did. I went and got regular hose clamps and put the second one back together and have put another 40,000 on it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-20-2017, 02:55 PM   #15
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
My main tow truck is a Dodge... almost every day im dragging home a Ford or Chevy... the first wood deck trailer had a chevy sign on it with the words "your chevy here" I was towing so many of them
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-21-2017, 11:14 AM   #16
Coley
Coley's Avatar
Ahhh the old Dodge vs Chevy vs Ford debate....lol.
I don't have too many bias's with the new trucks they all seem to be a lot better built than they used to be.
I haven't been in a newer dodge in a few years but a buddy of mine uses them as shop/business vehicles and although they are good trucks he definitely notices the quality difference downwards in comparison to a new GM....noting that they are less money to buy, making them attractive for businesses.
He says they seem to be a little 'tinnier' in their operation and cheaper in their interior appointments and quality....but that doesn't mean they are not a good truck.
One thing I noticed was they can be quicker to start rusting. I was on holidays this year back east in an area that uses a fair amount of salt on the roads. One thing i noticed was the abundance of newer dodges that were already starting to rust around the rear wheel wheels....very similar to the old '70's square body Chev's.
If I lived in a 'high salt' area I definitely would be 'rust-checking' those areas of the truck as well as the cab, rockers, etc.
Again...I always believed Dodge to make very good engines...and on size for size they certainly used to perform better than the GM's or Fords.
my two bits.
Coley
2000 Dodge Ram 1500
Old 10-22-2017, 06:59 PM   #17
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
All you need is a new cap, new stat and your good to go.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-25-2017, 08:35 AM   #18
I would assume the clamp got loose in time or you have the cheesy clamps Deland experienced. Clean the surfaces and reattach and see what happens. All brand trucks have upper radiators that clamp to the outlet neck on a radiator at one end and the thermostat housing on the other end. They all fasten using clamps that can work loose...or hose diameter shrinks at clamp. Ever notice how a hose flairs in time beyond the clamp? They all use antifreeze/coolant which is slimy. This problem has an equal likelihood of happening on any brand. But no way do Dodges break down less than GMs. I'll guarantee more Dodges and Fords get loaded on trailers with bad transmissions than GMs by a long shot...and that is a pricey one! I hardly ever see a Dodge rollback.
