Old 10-18-2017, 02:26 PM   #1
Hazieview
Building Dreams out of Dimes!
When I turn on my headlights my turn signal indicators both come on also...?
Well... When I turn on my headlights both of my green turn signal indicators also turn on. Also when I flip on either turn signal they do not work. With the headlight off everything works fine... Any ideas? It sounds like I have some wires crossed somewhere...
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 10-18-2017, 03:43 PM   #2
akart
Re: When I turn on my headlights my turn signal indicators both come on also...?
Check your fuses.
akart is offline   Reply With Quote
Old 10-18-2017, 04:55 PM   #3
wilkin250r
wilkin250r's Avatar
It might not be wires crossed, it might be a bad ground connection in your headlight circuit. Just enough to allow low power from your blinkers to work, but the high power from the headlights causes problems.
The analogy would be a slow sink drain. A slow trickle will go down the drain fine, but as soon as you turn your faucet on full blast, it backs up and starts leaking water into other areas.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 10-18-2017, 04:57 PM   #4
Jaysonb
Jaysonb's Avatar
I would guess that you have a bad ground.
Jaysonb is offline   Reply With Quote
Old 10-18-2017, 05:21 PM   #5
ZUKE
It means you have a bulb out on the side the signal is pointing
ZUKE is offline   Reply With Quote
Old 10-18-2017, 06:32 PM   #6
Hazieview
That makes since fellas I appreciate it! Hopefully I can find a ground wire unhooked somewhere.
SB400 350th
Old 10-18-2017, 06:33 PM   #7
Hazieview
All bulbs are working.
SB400 350th
Old 10-18-2017, 06:37 PM   #8
Hazieview
One more stupid question... Do the parking lights (the ones behind the grille) flash along with the front side markers? It's been so long since I had my truck inspected that I honestly can't remember. Lol
Mine parking lights don't flash... If they are suppose to then maybe I have the wrong bulbs...
SB400 350th
Old 10-18-2017, 07:33 PM   #9
TKCR
TKCR's Avatar
Yes they are supposed to flash
Old 10-18-2017, 11:10 PM   #10
bilfman
bilfman's Avatar
If you put in LED bulbs it can do that.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 10-19-2017, 05:04 AM   #11
TKCR
TKCR's Avatar
This is correct, LED bulbs can make all kinds of weird things happen.
Old 10-19-2017, 11:13 AM   #12
Hazieview
My turn signal indicators are actually LED bulbs. Perhaps that is my problem...?
SB400 350th
Old 10-19-2017, 12:16 PM   #13
Hazieview
I ended up changing out my Flasher with a 'LOUD' LF12 Novita Turn Signal Flasher from Autozone. I also found a broken ground wire on the passenger side running light (behind the grille). Thank you guys for all your help. Hoping to get my inspection tomorrow!
SB400 350th
Old 10-19-2017, 05:22 PM   #14
cadillac_al
Whenever I ask for a "loud" flasher the parts guys give me a dumb look. I am going to try that one. thanks.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-19-2017, 10:21 PM   #15
Hazieview
Hahahahahaha! I believe it!!! I tell you what bud, the 'LOUD' Flasher is the only way to go when you have a loud true duel exhaust. Haha!
SB400 350th
