10-19-2017, 01:39 AM | #1 |
Holley Help
I have a Holley Carburator (that I'm trying to rebuild) with a Hole in the Metering Body Assembly Primary(?) that was originally covered with the metal putty stuff. Now I know I can pay ~$8 & cover it again (with putty), but I wouldn't mind knowing what it does, & if there is something that I can get to do the proper repair. Thank you for any responses.
(I bought Holley Part #4321 / 26-59 Metering Block Spark Fitting & 3/16" CA360 Brass Fitting Plug. This hole is much smaller than 3/16th") |
10-19-2017, 09:28 AM | #2 |
Re: Holley Help
Ported vacuum source.
10-19-2017, 10:13 AM | #3 |
Re: Holley Help
10-19-2017, 10:10 PM | #4 |
Re: Holley Help
Thank you both for the ultra quick response! Guess I'll be using the metal putty to fix it then. Someday in the future tap & insert some brass thing more permanent.
