Old 10-19-2017, 12:25 PM   #1
Bigdav160
Bigdav160's Avatar
Hydroboost Installation Q?
Has anyone mounted a hydroboost unit to the factory vacuum booster bracket?
I have seen CaptainFabs brackets that eliminate that feature and mount the hydroboost unit to the firewall.
I've also heard concerns that the pedal is touchy after conversion (mounted to firewall). Sometimes attributed to incorrect pedal ratio(?) and nothing to do with CaptainFab's brackets.
I noticed the factory power booster bracket has a small amount of lever ratio built into it.
It also looks like mounting the hydroboost would be a snap as it is almost the same length as my 3/4ton vacuum booster and the mounting holes are nearly the same.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-19-2017, 01:44 PM   #2
Custom 68
Custom 68's Avatar
Re: Hydroboost Installation Q?
I made a mount for mine and mounted it close to the firewall. It is not touchy it is very controlled seems even more so than the old vacuum booster setup.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-19-2017, 02:04 PM   #3
cleszkie
cleszkie's Avatar
My hydro-boost is mounted that way with the bracket. It doesn't look as clean as mounting directly to the firewall, and the master cylinder comes pretty close to the alternator. However, the pedal ratio adjustment that you get with the bracket makes for a very user friendly pedal action (not touchy).
cleszkie is offline   Reply With Quote
Old 10-19-2017, 02:38 PM   #4
jeffahart
jeffahart's Avatar
I know you're asking about using the vacuum bracket, but why not use the firewall mount that came with the booster? I'm pretty sure the rod on the vacuum was longer. I even had to build up the pedal arm so the rod could reach. Here's the thing with me on the hydroboost conversion. I figured if I mod the rod once, then if I ever needed a new booster, then I'v be in for another rod mod. Now I can just grab off he shelf and stuff into the heap! So I added some metal to the pedal!
But, yea, once you get the pedal/rod settled it's an easy upgrade. I would just get a booster that matches the master!
White K20
jeffahart is offline   Reply With Quote
Old 01-28-2018, 05:55 PM   #5
argonaut
argonaut's Avatar
cleszkie,
Are you saying that you mounted the hydroboost directly to the original bracket with the lever setup? Any pics?
I converted mine a couple months ago and mounted the hydroboost using the original bracket. It feels like I'm not getting as much boost as I'm used to with the conversions I did on my 64 and 66 pickups. I was thinking that it is because the lever on the blazer system effectively cuts the pedal pressure in half. Or maybe my pump isn't putting out enough pressure? Regardless I'm wondering why GM used this funky lever setup on the 72 blazer.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
