10-19-2017, 03:05 PM | #1 |
Cab Transported in Bed of Truck?
This seems like a weird question, but has anyone tried to fit a 67-72 cab in the back of late model silverado? I found a cab that's too good of a deal to pass up, but my uncle has my trailer on the other side of Missouri.
I'll probably end up renting a uhaul trailer for the day, but I took some measurements on my 67 cab and the bed of my 07 short bed GMC, and it looks like it could fit. Is this possible, has anyone done this before, or am I just crazy? |
10-19-2017, 03:27 PM | #2 |
Re: Cab Transported in Bed of Truck?
I wish i could comment about the late model pickup. I can tell you my 69 cab will not fit in the 69 bed. Bruce
Posted via Mobile Device |
10-19-2017, 04:06 PM | #3 |
Just did a search and some say they fit ok sideways in the bed of full size truck.
10-19-2017, 04:08 PM | #4 |
If the bed was wide enough....I've seen pics of it being done.
The trailer would have to be more convenient though, as far as getting the cab loaded and unloaded. Bring along plenty of wood blocking and even cushions, tie down straps, rope, etc. I'd try and get a spare tire for the trailer also. Renting a trailer is cheaper than missing out on a good cab. Last edited by In The Ten Ring; 10-19-2017 at 04:35 PM. |
10-19-2017, 06:53 PM | #5 |
Petroleum User
Take some 2x6's and straps. And a cordless circular saw. Let it ride the rails if necessary. Make your bed a flat bed. Just use cloth under the boards so it won't mess up your paint. The late silverado's are about 63" at the tail, and the '67-'72's are about 65".
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto Last edited by 71sierragrande; 10-19-2017 at 07:12 PM. |
10-19-2017, 06:57 PM | #6 |
BlahBlahBlah
Ive carried cabs in the backs of our trucks (67-72) many times. I have no idea on the sizes of later model truck beds though.
10-19-2017, 07:13 PM | #7 |
I took my home Depot 6'x12' trailer and me and the seller had it loaded in 20 seconds and on my way.
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
10-19-2017, 07:22 PM | #8 |
For clarification- I bought a 69 K10 from Sunsoaked69 in Yuma ,AZ. I hauled the project (no eng,trans, t-case) back to Western IA on a car trailer. Once i was home i disassembled the truck and to conserve space thought i would put the cab sideways in the box. No go! As others have mentioned if you block it up above the tubs, it will fit fine. But certainly will not set on the bed floor.
10-19-2017, 08:40 PM | #9 |
Your late model has notches just above the fender wells for 2x6's. lay 2x6's across those and lay a piece of plywood on top. Turn the cab sideways in the bed.
I keep 4 2x6's and a piece of plywood in my truck all the time.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
10-19-2017, 09:05 PM | #10 |
BlahBlahBlah
This sounds like a good mod to do to our trucks. Ill have to see if I can find a picture to see what you are talking about
10-19-2017, 09:17 PM | #11 |
laying low
Here's a peak.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-19-2017, 09:24 PM | #12 |
Works great. I took my long bed with camper shell to Memphis a while back and picked up a bunch of body sheetmetal.
I put some of the pieces on the bottom below the plywood shelf and the rest on top of it.
10-19-2017, 09:31 PM | #13 |
Wow guys, thanks for all the tips! I never paid attention to those notches in the bed before. I'll post pictures of it all loaded up this weekend.
10-19-2017, 10:16 PM | #14 |
Petroleum User
The 73-87s actually had notches for 2x6s. I wasnt even talking about that. If necessary, run 2x6s across the rails(top of the bed). There is nothing under 8 feet wide that you cant carry if you use your head(and straps)
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
10-19-2017, 10:36 PM | #15 |
I hauled one back from Carlisle, PA in the bed of a 2000 F250 with no problems. Used lots of straps and paid ridiculous amount for tolls on the turnpike.
10-20-2017, 06:38 AM | #16 |
People do it, but I never would consider it. Just not worth the risk of ruining a bed , the cab, or both. That's awful high up there to be lifting a cab compared to the ease of trailer loading. I'd consider the cost of rental to be a minor insurance cost. Risk of damage comes at loading, transporting, and unloading.
10-20-2017, 06:50 AM | #17 |
I have done it, but not in a late model yr truck, but I would think the measurements would be very similar. I turned the cab side-ways and the transmission hump fit over the wheel well in the bed. You may need to support the cab with a pallet or tires, and tie it down well so it doesn't move and drive easy. The tough part is being able to lift it high enough to get in & out.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
10-20-2017, 08:12 AM | #18 |
BlahBlahBlah
Well this is a pretty cool feature. I wonder if you could do something like this to a 67-72 bed. Ill have to measure the height of the wheel well.
10-21-2017, 05:30 PM | #19 |
With two 2x6 across the bed and plywood on top it's pretty easy to slide a cab into the bed. I also put a support under each 2x6, and should have put one at the end of the plywood. Thanks to everyone's comments I was able to get the most solid $250 cab I've ever seen, and it came with really clean doors that I have stuffed in the back seat of my truck.
