10-19-2017, 05:13 PM | #1 |
Firewall Questions
I'm finally getting around to putting my Blazer back together after 4 1/2 years. I'm working on the firewall today, and I have a few questions:
1. The wiring coming through the firewall in the red circled area was cut off by the previous owner. The hole in the firewall looks like it was a factory hole and the grommet looks factory, but I have no idea what the wiring is. Any ideas? 2. I need to weld up the hole next to the steering column (no idea why the P.O. made it) but I also have air coming through the steering column seal. How do I get to the seal to replace it? 3. Is there supposed to be a grommet of some type around the brake actuator rod? *Whoops, I just realized I forgot to attach the picture. Here it is: Thanks for your help.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 10-19-2017 at 09:01 PM. |
10-19-2017, 10:47 PM | #2 |
Re: Firewall Questions
1. I have 2 cabs (70 & 71) neither have that hole
2. I think you need to remove the column, the seal unscrews from the inside of the cab 3. there is a boot that goes on the brake rod Last edited by B. W.; 10-19-2017 at 10:56 PM. |
10-19-2017, 11:33 PM | #3 |
Thanks, BW. I don't recall seeing that hole on other 67-72 trucks I've owned, but it looks so clean I thought it might be factory. The P.O. had a CB radio at some point, so it might have been for that. I might just end up welding it up, unless someone else recognizes it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-20-2017, 11:16 AM | #4 |
OK, so I was ready to weld this up, and I decided to take a look on the inside. The wires go to the relay indicated by the arrow. Looking at a pic posted by VetteVet I think it's the TCS relay, so I can eliminate it anyway. I just want to be sure before I proceed. Can anyone confirm this for me?
10-20-2017, 06:24 PM | #5 | ||
"I ain't nobody, dork."
It is the old "spark knock" wiring. My 1972 GMC had it located in the same spot too.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-20-2017, 08:00 PM | #6 |
Thanks. I'll delete it and weld up the hole.
