10-29-2003, 03:34 AM | #1 |
Stylin
Brake lights
ok its taken me a hell of a long time to notice the obvious. theres a connector on the column not the one with the fins on it but the one to the right of it, the white wire is not connected this is the sole reason why my damn brake lights do not work. ive inspected the connector and it seems like its just a big connector( being that it just joins the wires together nothing else) there is a white wire on the otherside where it is connected im wondering if i can cut and splice these wires together?
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
10-29-2003, 03:39 AM | #2 |
Professional Grade
Hmm... I wonder if maybe my reverse light cable is broken or something...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-29-2003, 11:19 AM | #3 |
Stylin
heres a pic of what im talking about
10-29-2003, 11:21 AM | #4 |
BeWarE tHe eViL CrAnkTOe!
I would get a volt meter or test light and attach it to what you believe what is the correct light and hit the brakes to see if that is it for sure.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
10-29-2003, 04:25 PM | #5 |
Stylin
that wire is the brake lights ive already touched it back to the connector while ive had the brake switch on and they light up everytime
10-29-2003, 04:32 PM | #6 |
brake light wire
you can splice the corresponding wires together. if you have to replace the turn signal switch you will have to seprate them to do that. the plug is there to make it easier. if you are good at doing a cold joint solder you can solder the wire back to its terminal by removing the terminal. if you want to do that let me know and i will send a pic of how to get the terminal out. either way will work.
troy wilson |
