Old 10-20-2017, 06:11 PM   #1
Jonny Hotnuts
6 to 5 lug conversion.
How hard is the rear axle swap? Is it worth the trouble?
I am finding the wheel selection for 6x5.5 to be thin and more expensive than the 5x5 options.
Planning on drop spindles in the front with disc brake conversion, so the front will be easy.
Is there a kit that has the axles, drop spindles and brake conversions in one?
~JH
Jonny Hotnuts is offline   Reply With Quote
Old 10-20-2017, 06:19 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 6 to 5 lug conversion.
Axles are easy. Just get the correct length 5 lug axles. I'm assuming we're talkin' about a truck 12-bolt. Pop the rear cover off, remove the cross pin retaining bolt, slide the pin out, push the axles inward and remove the C-clips, now slide axles out. Slide new axles in, install C-clips and pull axles outward to seat the clips, install cross pin and pin retaining bolt, reinstall cover and fill with new gear oil.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
