![]() Join Date: Nov 2014
Chromed our grill
What do you all think?? Sent our aluminum grill to be chromed. This is how it turned out. Now do we get a chromed center plastic or put stock silver back in it??
Old member
Who did the chrome work? Look great!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Jan 2001
Re: Chromed our grill
It looks great. I think a chromed eggcrate would be too much for most trucks.
Mind if I ask how much the chrome cost?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Electro plating of El Paso. It was 550. With headlight trim rings. But the grill was a stock aluminum one. The cost would be about the same as an aftermarket one basically. And we know this one fits the truck it came off of. So should be an easy fit putting it back in.
VERY nice!
Nice grill, I've used them for my hubcaps. They were easy to work with and fast turn around. What about a black center...
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
Definitely no chrome insert. Grey will look just fine
![]() Join Date: Apr 2008
X2 ^ (and the chrome looks great!)
![]() Join Date: Oct 2009
another vote for stock gray. how or will you paint the factory black on the surround? would be kinda difficult to make it stick on chrome i'm guessin. looks real nice!
Yes the black is gonna go back on although the grill didn't have black on it before we sent it. But am gonna go call to paint shop and see what we can get to stick to it. It was the stock grill from a one owner truck so don't know why it wasn't on there before. Do all 1971 Chevy have the black around headlights??
BlahBlahBlah
Did they have to do any work to the grill before chroming, or was it in perfect shape when you sent it in?
And like most others I would definitely keep the inner grill stock color.
Yes, all 71s have the black on the grille surround around the headlights. In fact, 71s, unlike any other year, also have a black perimeter stripe on the grille surround. Its seldom seen because it wore off of most stock grilles over time - as did at least some of the headlight ring black too usually. Nobody sells a 71-specific grille surround, only 69-72 common and then an owner would need to add a 71 perimeter stripe to be correct (if desired). Most don’t normally put the perimeter ring back on unless it’s a full blown numbers resto, it’s just gonna wear off again anyway! But it is worth at least putting the black on the headlight area, personally I think that makes a big difference. Just looks like something is missing to me if it’s not there. I don’t have a ref pic of the 71 grille handy, will post one tonight unless someone beats me to it (hopefully)
#13 |
![]() Join Date: Nov 2012
This is the stock grill on my original paint 71. As you can see, the black perimeter stripe is almost entirely gone. There is a little at the bottom corner below the headlight as well.
#14 |
Paint the egg crate section black. That'll make the chrome really pop.
#15 |
![]() Join Date: Aug 2008
#16 | |
#17 |
![]() ![]() Join Date: Feb 2009
Chrome looks awesome. I'm with some others, factory "silver".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#18 |
Had a couple of really small dings in it and almost like a cut on drivers side toward top of headlight. They fixed that also. And it was dingy looking. We figured when we get around to painting it its gonna look really bad with new paint. Cause with the aluminum grill because they are anodized you can't really make them shiny. We don't have funds for NOS stuff.
#19 |
#20 | |
![]() Join Date: Jul 2015
Well done to say the least. Thanks for the inside info on the fixes also. I have seen too many grilles go to the way side due to a couple of dings. |
#21 |
The people whom chromed it had a lot of problems doing it. They had it for about 10-12 weeks we weren't in a hurry to get it back but on portions of the curve at bottom of grill wasn't coming out very well. They finally were able to get it done. But they told me that they weren't going to do anymore of this year aluminum grills. But bet they do.
#22 |
I bet they'll do more also- for more $. Do you think that you could mask off all the chrome that doesn't get painted & then scuff the areas that you want to paint with coarse steel wool? As long as you can "dull" the chrome, I think the paint will adhere
#23 |
Good idea. Just gotta be careful.
#24 |
I paid 750 for mine to get done In houston, most shops told me they would not chrome a aluminum grill or wouldn't give a warranty
#25 |
![]() Join Date: Jan 2010
I would like to get my 67 gmc body mouldings done in chrome. That grill looks real nice. It will look sharp!
