10-23-2017, 08:26 AM | #1 |
First start - off to tuner next
I started it up for thw first time yesterday. Now it is off to the tuner to get it running right.
2004 lm7 motor out of 2wd chevy silverado. Stock 4l60e transmission. 80lb injectors. Turbo and intercooler from vs racing sloppy mechanic kit. Flipped truck manifolds and custome fabbed 2.5" hot side and 3" cold side. 3" down tube to a race venom exhaust. Boyd tank with in tank pump. Modern vintage systems provided an awesome cut down harness. I am anxious to see how much power it produces on the dyno. |
10-23-2017, 12:48 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: First start - off to tuner next
Nice!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-23-2017, 08:06 PM | #3 |
WOW!!! Have fun with that!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
10-25-2017, 11:59 AM | #4 |
So that is what you do with all of your spare truck exhaust manifolds !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
10-25-2017, 12:56 PM | #5 |
Nice build!
The stock 4L60E is not gonna last. They're just not up to the task when it comes to the brutal torque of a turbo. As for the fuel system, how big is the pump and what type of fuel? That'll likely be your limiting factor. If its a typical walbro 255, I'd say 475ish to the tire on gasoline is about it. Watch those fuel pressures and duty cycles closely.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
11-04-2017, 01:45 PM | #6 |
update???!!!
11-04-2017, 07:14 PM | #7 |
No update yet, still waiting to get in to the tuner.
As for the pump, it is an In-Tank Aeromotive Stealth 340. I used the truck manifolds flipped over to make the hot side. I am guessing the trans will last until I put bigger tires in the back. I still have the skinnies on the back, so I wont be able to get much power to the ground. |
11-08-2017, 07:10 PM | #8 |
So I changed direction a little. I just picked up a copy of HpTuners and I am going to do the base tune myself. Final tune will be done by a professional on a dyno.
First step I turned off the VATS and adjusted the fuel injector setting for the 80# injectors. She runs!!! https://youtu.be/FBG2dXeaZtI |
11-08-2017, 07:24 PM | #9 |
Post Whore
sounds great...!!!
11-08-2017, 10:57 PM | #10 | |
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
11-08-2017, 11:32 PM | #11 | |
11-10-2017, 09:32 AM | #12 | |
http://www.vsracing.net/catalog/prod...oducts_id=1320 |
11-11-2017, 06:36 PM | #13 | |
Thanks for the info. Will be looking at your build for updates.
11-15-2017, 08:46 PM | #14 |
Making a bit more progress. The grill is back on with the intercooler tucked in nicely behind. I also got the 2 bar map sensor installed and mounted under thw vortec engine cover.
It is idleing good, so now I need to get it road ready to do some driving tuning. |
11-16-2017, 12:32 PM | #15 |
How was the fit with the grill and intercooler? Any pics of mods you had to make to get it to fit?
11-16-2017, 02:20 PM | #16 |
I did not take any pics, but I did have to modify the grill. I cut 1.25 inches off the upper flange. No other mods were required. I will see if I can get a decent pic with it on the truck.
