Old 10-23-2017, 11:22 AM   #1
gable74
gable74's Avatar
Exhaust Manifold Flange Size
He guys,
I bought some after market Rams Horn manifolds last year and just got around to installing them this weekend. They were pretty easy to install and everything went smooth. I am dropping the truck off at the exhaust shop Friday to get the tubes ran. I have some quiet Walker mufflers to hand over but I do not have the collector flanges that bolt to the manifolds. They looked like they were the ball type flanges. I am not an exhaust expert so I am trying to figure out if....
- There is a difference between the donut type and the ball type flanges?
- What size is the flange? 2.5"?
- Would a decent exhaust shop already have what they need to transition from
the manifold to the pipes?
I plan on calling them in a little bit to verify some of these questions but I wanted to see what you all had to say too.
Thanks,
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 10-23-2017, 11:53 AM   #2
gable74
gable74's Avatar
Re: Exhaust Manifold Flange Size
Looks like the flange on the manifolds is a 2.5" and donut style. Can I use a standard reducer flange with a donut? Something like this?
https://www.summitracing.com/parts/big-10005flt
Old 10-23-2017, 08:37 PM   #3
B. W.
B. W.'s Avatar
No - leakage will occur!
I used a pair of Walker 41248 elbows coupled with Walker 31883 flanges & Fel-Pro 60986 donuts. I sawed up the elbow to get the desired fit
The exhaust should be able to form the end for the donut and the elbow.
B. W. is offline   Reply With Quote
Old 10-23-2017, 11:45 PM   #4
gable74
gable74's Avatar
Thanks for the info!
How much of this should a decent exhaust shop be able to handle. I feel like the flared tube at least should be able to be fabled up in the shop. I will pick up the donuts and rings just to be safe.
Old 10-24-2017, 10:05 AM   #5
B. W.
B. W.'s Avatar
A decent shop should have (or have quick access to) any part needed to make your exhaust. Post up some pics when done!
Old 10-24-2017, 11:39 AM   #6
gable74
gable74's Avatar
Will do....thanks.
