Cleaning up the bed
Started cleaning up the bed on the '66 C-20 today. Wondering what you guys have done with one in this condition. Most of the wood is still presentable--a few warps and cracks, looking more for preservation and care than just superficial looks.
Also, some pretty mysterious bolts are at the four corners of the bed. No doubt something to do with the camper hold down but I can't see it. 4 pairs of 1/4 bolts through the bed at the four corners. These are in addition to the obvious camper hold-down clips...slim |
![]() Join Date: Aug 2010
Re: Cleaning up the bed
Actually, you don't need to do much. Perhaps a light scrubbing with a not too stiff brush and a mild detergent will get some of the dirt off, but after that the wood will be fine left alone. Don't fall into the trap of thinking that it needs to be totally sealed to last. That type of wood (southern yellow pine) is quite durable and rot resistant without any help.
I absolutely can tell you what NOT to do, and that is cover it up with a bed mat of some sort that does not breathe. Getting wet is no problem, even soaking wet, if allowed to dry after. Staying wet is where problems start. I personally wasted a decent bed like yours once by attempting to protect it. Covered it with a heavy rubber mat and thought I did good until lifting the mat sometime after a heavy rain season. White hairy mold was everywhere and it went downhill fast from there. Lesson learned: If it gets wet, just let it dry. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
What was the original treatment that the wood got from factory?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
I bumped a couple threads on topic.
They might help you.
![]() Join Date: Jan 2002
i like the black BUT ?? what does the australian timber stuff look like ?? dark -light ? curious ? thanks mike
Similar topic here:
http://67-72chevytrucks.com/vboard/s...ad.php?t=74772
