K30 Wheels
I located a C20 with original wheels and hubcaps. Before I buy them, I'm wondering if they will fit k30 (cucv) axles. Both are 8 lug but, is there a backspacing or clearance issue otherwise?
Thanks, Mike |
Re: K30 Wheels
The wheels will fit, but the front hubcaps wont work. The 4wd has hubs.
Re: K30 Wheels
Thanks. I was hesitant because I saw a post selling 1 ton wheels that were 16.5 inch. I currently have 16 aftermarket wheels. I didn't know if that 1/2 difference makes a difference. Copy on the front hubcaps. I'll just need to find the open ones. Thanks
Re: K30 Wheels
the difference will be in the 16 and 16.5 tires dont mix/match rims .
otherwise yes 16" rims from gm fit the dana 60 k30 1ton axles. and be prepared to spend a few bucks for the harder to find k30 dana 60 front caps . but always good to ask before purchase
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: K30 Wheels
Sweetk30,
That's what I needed to know. Thank you for your help. Mike |
Re: K30 Wheels
Might want to keep an eye out for factory 16 inch. 16.5 tires can be a pain to find and are getting more expensive.
![]() Join Date: Mar 2003
Re: K30 Wheels
Re: K30 Wheels
these guys will have you covered on 16.5 for years to come . and from mild to insane tread styles.
http://www.intercotire.com/
| Bookmarks |
