Is this cab scrap?
Ok we'll I started to do some rust repair on my 67 cab and found a mess. The cab corners are shot. No problem. Rockers gone. No problem. Cab roof rusted around drip rails. Not ideal but ok. Passenger upper door frame on cab non existent. We're getting more serious. Finally the cab metal under the lower cowl is in bad shape and some around window frame. Now I'm second guessing myself if this cab is worth repairing. Not sure how I'm gonna fix the rust under cowl? Any thoughts will be appreciated.
![]() Join Date: Apr 2008
Re: Is this cab scrap?
You're in Texas- I would find a better cab. I think you'll regret not looking for a better one when you're in the middle of trying to fix this cab
![]() Join Date: Feb 2012
x2. It would be to far gone for me. Cut it up and sell some patch panels.
![]() Join Date: Nov 2004
I hate to see a 67 small window go to scrap... but man, that's crusty. You'll have to make some of those rusty panels or do a roof swap.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
I hate to see any of these trucks scrapped, but I would look for another. If you have have a great welder and patience you can fix it. Just will take some time and patience..
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
![]() Join Date: Mar 2011
I can tell you from past experience, You can locate a rust free cab from the southwest, go get it and end up with less money in it than you can fix that one. Now with that said, what you do depends on your budget and your timeline. From the pics of your cab, I see many hours labor and several dollars in repair panels.
For reference, in my case I loved the history of my truck and wanted to preserve that cab---expensive choice. Cost me right at $3000. just to make my Cab rust free. At that time I could have bought a rust free cab in Phoenix, pulled my trailer out to get it, paid food, lodging, gas-----and saved nearly half of what it cost me. (when I made the decision to keep my cab, I didn't know the complete extent of the rust).
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
![]() Join Date: Aug 2004
Go out to west TX and find a good cab. Last time I was down there, they were around. You could spend a ton of time and $ to get your current one right.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
I would find a better cab myself
Thanks for all the input! I'm going to look at a cab Saturday. Hopefully it's as good as he says.
The British restorer JadeMuttley has a series of rust repair videos that I found helpful. His approach was the main thing.. he just picks the worst spot; outlines about a six-inch by three-inch sections of it; makes a paper template; cuts out the bad section; and then hand-forms using his vise and workbench a small repair piece out of mild steel (20 or 22 gauge).
Once he has that piece welded in (Mig) and ground down and primed; he moves on to the next worst section. Amazing to me how a situation that can initially look hopeless is changed by just one or two of those worst spots getting fixed. Here's a link (wait ti he gets to the trunk on that Vitesse if you think yours is bad).. https://www.youtube.com/watch?v=wO_uE3M7FVg Triumph Vitesse restoration Part 1 HOW TO HD 720p jademuttley |
![]() Join Date: Jan 2001
Definitely beyond what I would feel comfortable with as well. But the rear window section looks to be in pretty good shape - you might cut that out to use or sell. Make sure you cut large enough to cover the large rear window area.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Born Psycho
![]() Join Date: Feb 2001
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#13 |
at least when you go look at the new cab you will know the areas to look for the rust. I went through three cabs before I found one that was useable with the normal cab corners and rocker panels.
#14 |
Well I looked at a cab yesterday. No luck. It was worse when than mine. So as Bobby Bouchée says "the search continues".
